Ss Or 1 Le???
I Have A 2002 Ss Does It Have The Same Size Sway Bars As A Reg Z28? If Yes Is The 1 Le A Good Upgrade? And Does It Have Rubber Or Poly Bushings On The Tie Rods And Swaybar? Want To Keep As Close To Stock As Possible Thansk
35mm front
21mm rear
Poly sway bar bushings
Poly end links
Stiffer springs
Different shocks over the regular F-body shocks
The regular F-body's got...
32mm front bar
19mm rear bar
Rubber sway bar bushing mounts
Poly end links
Decarbon shocks
Standard springs
I may be off on the bar sizes though as it has been a while since I had the size near me.
