Katech Corvette :D
CLINTON TOWNSHIP, Mich. – Katech Performance has made the Corvette C6 Z06 even better with more power and enhanced induction, cooling and exhaust. The C6 Z06 vehicle package (KAT-A4691) promises 600+ horsepower and fine finishing touches for enthusiasts who desire a truly unique Corvette.
To develop the package, Katech Performance consulted with endurance racing legend Dick Barbour of Dick Barbour Racing. Barbour's accomplishments include multiple 24 Hours of Le Mans and 12 Hours of Sebring class victories as well as three Sports Car Club of America (SCCA) championships.
"Katech's own rich motorsports history includes more than 50 driver's and manufacturer's championships," said Caleb Newman, vice president, director aftermarket operations, Katech Performance. "The C6 Z06 package draws from our collective expertise. We've crafted a vehicle worthy of the most astute Corvette aficionados."
The C6 Z06 package features a Katech Performance "Street Attack" LS7 engine with Katech forged 11:1 pistons, solid bushed titanium connecting rods, upgraded camshaft, high-lift beehive valvesprings, ultra-light titanium retainers and ported cylinder heads. Other modifications include a Katech adjustable billet aluminum belt tensioner, coil relocation brackets and paint-matched valve covers.
"Our Street Attack LS7 produces 600 horsepower for the C6 Z06," said Newman. "That's an increase of nearly 100 horsepower over stock. What we've created is one of the industry's most powerful yet durable and civilized engines. It's a thrill on the highway yet reserved on city streets. Our C6 Z06 is a true 600 horsepower daily driver."
Newman went on to explain that each Street Attack LS7 is hand built by the same technicians that produce championship winning engines for all Katech race programs. Each is meticulously calibrated and dyno-tested before leaving the facility.
Further C6 Z06 engine and exhaust enhancements include a Ron Davis custom aluminum radiator with integrated oil cooler, Goodridge oil cooler lines, high flow air filter, KoolMat race tunnel heat shield, Kooks ceramic-coated headers and a CORSA® 100-percent stainless steel performance exhaust system.
Katech Performance has enhanced the C6 Z06 transmission with a high-performance clutch and an RPM Transmission Stage IV T56 upgrade featuring 300M output shafts, bronze fork pads and cryo-treated, micropolished internals. Stoptech stainless steel braided brake lines and AP Racing Super 600 brake fluid have been added to ensure the C6 Z06 stops as quickly as it starts.
Inside, a Caravaggio hand-stitched steering wheel with a flat bottom, emergency brake boot and shift **** and boot make known the vehicle's elegant demeanor. Here the driver also will find a serialized Katech Performance manufacturer's plaque.
Story by Katech
Here are the specs:
In Detail
engine Katech Performance 'Street Attack' LS7 V8
position Front Longitudinal
valvetrain OHV, 2 Valves w/Cyl
fuel feed Sequential Fuel Injection
displacement 7011 cc / 427.8 cu in
bore 104.8 mm / 4.13 in
stroke 101.6 mm / 4.0 in
compression 11.0:1
power 447.4 kw / 600 bhp
hp per litre 85.58 bhp per litre
drive wheels RWD w/Electronic Traction Control
body / frame Composite Body Panels over Hydroformed Steel Frame w/Aluminum & Magnesium Structural Components
front brakes Vented & Cross Drilled Rotors w/6 Piston Calipers, ABS
f brake size 356 mm / 14 in
rear brakes Vented & Cross Drilled Rotors w/4 Piston Calipers, ABS
r brake size 340 mm / 13.4 in
front wheels F 45.7 x 24.1 cm / 18.0 x 9.5 in
rear wheels R 48.3 x 30.5 cm / 19 x 12 in
front tire size 275/35ZR18
rear tire size 325/30ZR19
steering Rack & Pinion w/Speed Sensitive Power Assist
f suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
r suspension Wishbones w/Upper & Lower Control Arms, Transverse Composite Leaf Spring, Monotube Shock Absorbers
wheelbase 2686 mm / 105.7 in
front track 1577 mm / 62.1 in
rear track 1542 mm / 60.7 in
length 4435 mm / 174.6 in
width 1930 mm / 76.0 in
height 1246 mm / 49.1 in
transmission Tremec M6 6-Speed Manual w/Transmission Stage IV T56 Upgrade
gear ratios 2.97:1, 2.07:1, 1.43:1, 1.00:1, 0.71:1, 0.57:1
final drive 3.42:1
Here is the car
The best thing about this car is that you can actually purchase the entire C6 Katech Conversion Kit straight from Katech. They don't list a price on it but I bet you it would cost a pretty penny... Trending Topics
The hood is straight out of World Challenge racing and is very functional at reducing coolant/oil temps, underhood temps and increasing downforce.
Of course, everything is optional and we tailor it to the customer's requests.
No tickets tomorrow at the Katech track rental.....
woohoo!
