Strange and Moser rear end GP
Old 03-03-2011, 07:30 PM
  #181
Kaltech Tuning's Avatar
Quotes sent.
Kaltech Tuning is offline
Old 03-03-2011, 07:35 PM
  #182
transbird95's Avatar
Hello, you have a pm..
transbird95 is offline
Old 03-04-2011, 05:29 PM
  #183
xtransxamx's Avatar
Brian - will call monday
xtransxamx is offline
Old 03-04-2011, 08:57 PM
  #184
fatboyzcamaro's Avatar
Default gp on rear end
hello i would like two quotes please sir.
9 inch rear
35 axle
lca relocation brkt
stock length
1/2 studs
full spool
4:30 gears
my stock rear is a 4 channel but i dont need no abs sir.
rear fully ready to bolt in car with my brakes and plates.
s60
35 spline pro race strange axles
rear oil
lca relocation brkt
1350 yoke
stock length
full spool
4:10 gear
c/m yoke
ready to bolt n car with my backing plates and brakes.
how much are new backing plates for either rear.thanks in advance.
fatboyzcamaro is offline
Old 03-05-2011, 07:16 AM
  #185
92gearhead's Avatar
9 inch rear
35 axle
lca relocation brkt
stock length
1/2 studs
full spool
4:30 gears
s60
rear oil
lca relocation brkt
1350 yoke
stock length
full spool
4:10 gear
c/m yoke
x2 !
92gearhead is offline
Old 03-06-2011, 07:35 PM
  #186
Responses sent.
Old 03-13-2011, 12:08 PM
  #187
spcearle's Avatar
looking for a quote on a 9 or 60
96 z 4 chan
stock width
lca brackets welded
something close to 342s
i live in bk and can pick it up and way of getting any deal since shipping isnt needed....im in the army and getting ready to deploy in fall and wanna play with the car this year
spcearle@aol.com
spcearle is offline
Old 03-13-2011, 01:42 PM
  #188
Firebirdgm2000's Avatar
1999 Trans Am 6-Speed Twin Turbo
Moser 9" Stock Width & mounting locations for Lca's and Torque Arm
W/ABS & Traction 4-Channel
backing plates
Black Powder Coating
28 spline w/ Detroit TrueTrac 4.10
E brake cable mounting bracket welded on
brake line brackets welded on
Fill & Drain Plugs Installed
Firebirdgm2000 is offline
Old 03-13-2011, 06:54 PM
  #189
Quotes sent.
Old 03-18-2011, 11:44 PM
  #190
johns777's Avatar
2002 Trans Am A4
Moser 9" Detroit Locker w/ 35 spline axles
3.73 or 3.75 gear ratio
Stock width and stock studs
4 channel with new rings
LCA relocation brackets
Drain and fill plug
all brake line/cable brackets welded on
Ready to be bolted in
Also a PST driveshaft if you carry them
Thank you, John
johns777 is offline
Old 03-19-2011, 09:12 AM
  #191
quote sent
Old 03-19-2011, 06:14 PM
  #192
J Rob 347's Avatar
hello i would like a price for
12 bolt for a 95 camaro
stock length no traction control
33 spline axles ready to bolt in
with the long 1/2 wheel studs
please quote with pos unit and
spool thanks
J Rob 347 is offline
Old 03-20-2011, 08:21 PM
  #193
Quote sent.
Old 03-20-2011, 09:40 PM
  #194
boydcoz71's Avatar
Price on a 12 Bolt and 9"
2001 TransAm
4 channel (with tcs)
Desired gear ratio - 4:10
Desired differential - tru-trac HD
Any additional options you know that you want. - LCA brackets welded on.
Stock width
boydcoz71 is offline
Old 03-21-2011, 07:30 AM
  #195
2001 TransAm
Stock width
PM sent
Old 03-22-2011, 05:59 PM
  #196
Busted 10-Bolt's Avatar
Two quotes please,
Quote 1)
9" housing & axle package
1" off each side
back brace
fill and drain plugs
adj LCA brackets
using stock brakes (1994)
No ABS
aluminum center section
spool, 35 spline
aluminum Daytona pinion support
1350 yoke
1/2 x 3" wheel studs
assembled center section, I assemble the rest
No powercoat
Quote 2)
Same as above but M9 housing + torquearm
Busted 10-Bolt is offline
Old 03-23-2011, 01:00 PM
  #197
Quotes sent.
Old 03-26-2011, 09:57 PM
  #198
CorbinLR's Avatar
2000 Trans Am
35 Spline
Stock Width, Bolt Pattern and Studs
Sealed Bearings
Stock Brakes
4 Channel ABS 47 Tooth
Adjustable LCA Brackets
CorbinLR is offline
Old 03-28-2011, 07:43 AM
  #199
Originally Posted by CorbinLR
2000 Trans Am
35 Spline
Sealed Bearings
Stock Brakes
I need a little more info. Which rear are you looking for? S60, 9 inch? What differential do you want? True trac, spool, etc?
Old 04-04-2011, 10:00 PM
  #200
Lightweight's Avatar
Is this GP still going on?
Lightweight is offline
Quick Reply: Strange and Moser rear end GP
