Strange and Moser rear end GP
#42
Dana s60
Year and model of the car 2000
ABS? 3 channel (no traction control) or 4 channel (with tcs) NO ABS 3 channel
Desired gear ratio 3.42 or 3.55 somewhere around there
Desired differential Tru-trac
Any additional options you know that you want.
shipped to 19085
Thanks Kaltech
shipped to 19085
Thanks Kaltech
#47
I would like a price on an S60.
1998 Camaro
3 channel
3.73 gears with the truetrac
stock width
35 spline axles
new backing plates
new drive shaft
newark ohio 43055
Thanks
1998 Camaro
3 channel
stock width
35 spline axles
new backing plates
new drive shaft
newark ohio 43055
Thanks
#50
How much for Strange 12 bolt or S60
2000 T/A
12 Bolt (less brakes)-33 Spline, 3.73 gears, SS Posi with reluctor ring, backing plates, 4-channel. stock length. Be able to fit stock torque arm
S60- True Track, 35 spline, 3.90 gears, Backing Plates, 4-channel, ABS Reluctor Rings. stock length. Be able to fit stock torque arm. How much for custom DS with it?
2000 T/A
#52
I need a qoute on an s60 and a 9". I want a limited slip differential and a gear around the 4.10 range. It's a 98 z/28 with the 4 channel rear. Please respond to poweraddr@yahoo.com . Thank you.
#55
Price on 9" and S60 both with driveshafts please.
Year and model of the car - 1995 Camaro Z28
ABS? 3 channel (no traction control) or 4 channel (with tcs) - 3 channel
Desired gear ratio - 3.73
Desired differential - price on spool and tru-trac please
Any additional options you know that you want. - LCA brackets welded on.
#57
Can I please have a quote for the following...
Year and model of the car 1997 Trans Am
ABS? 3 channel (no traction control) or 4 channel (with tcs)3 Channel
Desired gear ratio 4.10
Desired differential TruTrac
Thanks,
JB
Thanks,
JB
#60
Need a quote for 9", 12 bolt, and S60, with drive shafts if needed.
need direct bolt in with all mounts for a stock suspension 2000 Trans Am M6
4 channel ABS
3.73 gear or 3.70 if 9"
best street/ light strip duty strong center, no spools
stock width, can reuse my stock brake setup
need wheel studs slightly longer than stock, about 3/8 to 1/2 in longer
want a rear i cant break on the street tires, and unlikely to break with 450 whp on slicks with an M6, would like to not be able to hear it screaming inside the car on deceleration too, thanks
4 channel ABS
