Strange and Moser rear end GP
Old 04-01-2010, 12:55 PM
  #101
Patsy57's Avatar
2002 TA WS6
3 Channel abs
4.11
Trutrac
35 spline axels
Aluminum cover
Patsy57 is offline
Old 04-01-2010, 02:55 PM
  #102
Kaltech Tuning's Avatar
Responses sent.
Kaltech Tuning is offline
Old 04-01-2010, 07:11 PM
  #103
ssowned's Avatar
Please price out the Dana S60 Rear End:
Car: 2001 Camaro SS M6
4 channel ABS
3.90 gears with truetrac
stock width
35 spline axles
new drive shaft
ready to bolt in
shipped to 85041
ssowned is offline
Old 04-01-2010, 10:11 PM
  #104
Numba1Stunna's Avatar
Price on 9", 12 bolt and S60
2002 Camaro SS
4 channel (with tcs) new reluctor rings
Desired gear ratio - 3.90 or 4.10 or 4.11
Desired differential - tru-trac HD
Any additional options you know that you want. - LCA brackets welded on.
Stock width
shipped to 02769
Numba1Stunna is offline
Old 04-03-2010, 11:21 AM
  #105
Responses sent.
Old 04-03-2010, 11:20 PM
  #106
Restricted User
Irby's Avatar
Default rear end
9" and 12 bolt
1996 Z28
has abs
not sure if its a 3 channel or 4 channel it has no TCS
3.55 or 3.73
Tru Trac
35 Spline axles
shipped to 75087
Irby is offline
Old 04-04-2010, 02:06 AM
  #107
airforcemanss's Avatar
9"
3 channel
abs
3.73's
airforcemanss is offline
Old 04-04-2010, 02:10 AM
  #108
9"
3 channel
spool 35 spline
with and without abs
3.73's/ 3.89's
lca's welded on or additional adj. holes
drain fill plug etc...
Old 04-04-2010, 10:51 AM
  #109
Responses sent
Old 04-04-2010, 01:52 PM
  #110
nazztman4739's Avatar
2001 ss camaro price on a budget rear posi with tcs and something between 3.73-4.11 range
nazztman4739 is offline
Old 04-04-2010, 09:42 PM
  #111
KBG
KBG's Avatar
2001 SS.....S60
3 Channel
3.73 with true trac
add strange driveshaft
add black strange differential cover
black powdercoat (does strange do that??)
LCA relocation brackets??
zip is 39532
KBG is offline
Old 04-05-2010, 06:30 AM
  #112
slowec's Avatar
Price on a s60
98 Z28
no abs
3.73 tru trac
35 spline
drive shaft
adjustable torque arm and lca
slowec is offline
Old 04-05-2010, 06:53 PM
  #113
Eddie.ci's Avatar
1998 z28, 3 channel, stock width, 3.90 gears, & driveshaft, true trac
price on dana 60, and 9in.
Shipped to 07740
Eddie.ci is offline
Old 04-05-2010, 07:53 PM
  #114
responses sent.
Old 04-08-2010, 09:17 PM
  #115
dcvingv6's Avatar
Ordered today... thanks guys!
dcvingv6 is offline
Old 04-12-2010, 02:16 PM
  #116
DanDan's Avatar
1999 Firehawk Transam
3 channel (no tcs)
3:42
spool
DanDan is offline
Old 04-12-2010, 02:52 PM
  #117
Gregorya24's Avatar
can you do a axle and housing only?
Gregorya24 is offline
Old 04-12-2010, 05:00 PM
  #118
barkingspud's Avatar
  • 2004-2006 GTO M9 (Kit)
  • Backbrace
  • Wildwood Drag Brakes w/Drilled Rotors
  • Aluminum Thru Bolt Center Section
  • 40 Spline Axles w/Spool
  • Gun Drilled/Flanged Axles
  • 5/8" Studs
  • Powder Coated Housing
Obviously, you're going to need to call the good folks at Moser as this isn't a part number yet but it is available. Thanks in advance!
barkingspud is offline
Old 04-13-2010, 01:40 AM
  #119
quik01ss's Avatar
Thumbs up
Got my S60 rear end today and painted assembled and installed it what a deal came right to me residential door and straight into my garage no more breaking my 10bolt!
quik01ss is offline
Old 04-13-2010, 09:48 AM
  #120
qc97z's Avatar
Please quote for me:
for '97 Z28 M6
Strange 12 bolt
4 Channel (ABS w/TCS)
33 spline axles
3.90 gears
Quote both Eaton posi and TrueTrac HD
Drain/Fill plugs
Painted or powdercoated black.
Thanks!
qc97z is offline
Quick Reply: Strange and Moser rear end GP
