Strange and Moser rear end GP
#122
2000 Trans Am
Strange 9"
3 Channel
Wavetrac
Welded LCA relos
Drain and Fill Plug
Driveshaft to match
Long style TQ arm (tranny Mount)
Stock Brake backing plates
Stock swaybar mounts
E brake cable mounting bracket welded on
brake line brackets welded on
Ready to bolt in
Quiet Gears also
Pricing on options for lightening it.
Strange 9"
3 Channel
Wavetrac
Welded LCA relos
Drain and Fill Plug
Driveshaft to match
Ready to bolt in
Quiet Gears also
#124
Just wanted to give props to Kaltech!!!
I received the rear on Friday, and the driveshaft will be here tomorrow, 11 days from the order placement.
Great turn around time, price, and Customer Service, which sometimes is lacking in businesses these days.
Thanks a lot guys...
--Mike
--Mike
#128
Price on a 9" (whichever is cheaper, moser or strange, doesn't matter) for 99 camaro torque arm car with 35 spline axles, housing and axles package, no center section. Back brace, no abs, fill and drain plugs installed, lca relocation brackets installed, and 5/8" x 3" studs as the options. Also, don't know if you can, but I need the pads welded on the rear to mount my bmr extreme duty anti-roll bar to, if not, i'll buy them and weld them on myself. What is the most it can be narrowed on each side without interfering with the stock lca mounting points? I wanted 4" each side so I could run a 15x10 3.5" backspacing rim to get a nice deep dish rim back there, but I heard somewhere you can only do 3" per side. Let me know a price, I just sold my 12-bolt and am ready to order, thanks alot, appreciate it!
#131
I am looking for the Strange 60 (stock width) for my 99 Pontiac Trans Am.
4 Channel
Trutrac
4.11's
1350 yoke
LCA relocation brackets
Aluminum diff cover
Prices with and without the the Driveshaft would be great. Prefer chromoly for the driveshaft.
I can send in my backing plates, etc as it is not my primary driver.
4 Channel
Trutrac
4.11's
1350 yoke
Aluminum diff cover
#132
Price on a 12 bolt housing and Axles
1968 Camaro
Multileaf
Big Bearing Ford Flush mount ends ( for LS1 style disk brakes )
I need the overall length to be 58.75 from flange to flange.
Shipped to 27253
Thanks, Dion
1968 Camaro
Multileaf
Shipped to 27253
Thanks, Dion
#137
4 Channel
Trutrac
4.11's
1350 yoke
Aluminum diff cover
4 Channel
Trutrac
4.11's
1350 yoke
Aluminum diff cover
Anything?
#140
I would like a quote for an strange 12 bolt
its on a 2000 trans am 6 speed
options:
4:10's
detroit locker
aluminum cover
3 channel abs
chrom moly yoke
33 spline
Anything else u think I might need. The car is a DD driver and take to track occasionally.
Or whatever would work best for me also best price please.
options:
4:10's
detroit locker
aluminum cover
3 channel abs
chrom moly yoke
33 spline
