Strange and Moser rear end GP
#162
Can I get a price for an S-60, 4.30 gear, trutrac, aluminum cover, 4 channel, with new backing plates, cromoly yoke. Also need a cromoly driveshaft with a forged or cromoly yoke. Shipped to 18337. Thanks
#163
may i get a quote for a s60 4 channel with my backing plates true trac with yukon 3.70 gears strange chromoly drive shaft set for 2002 camaro ss with 4l80e trans 35 spline axles and upgraded yoke.
thanks shipped to a business address 32904
#165
I have a 2002 ws6 what would it cost for a s60 with 4.10 true track 4 channel abs backing plates also what is a detroit locker and what does it cost? i would also need the driveshaft to go with it also can the whole rear be powder coated or just the cover? im in merrick 11566
#169
99Camaro
9" w/ back brace, stock width
3 channel (not required)
stock brakes
3.70-3.89 lightened gears
Wave-trac or det locker
fill cap
powder coated
iron ctr section
forged alumn pinion supt
strange axles
arp 2.5" studs
stock brakes
fill cap
powder coated
iron ctr section
strange axles
arp 2.5" studs
#170
Two quotes please:
2000 Pontiac Firebird Formula.
Strange S60
Stock Size Studs 12mm x 1.5
Gear Ratio 3.73
4 channel ABS with reluctor rings
35 Spline True Trac
Stock Brakes
New Backing Plates
Pinion Yoke Chromoly
** New Shorter Compatible Drive Shaft **
Shipping address: 91001
Strange 12Bolt
Gear Ratio 3.42
35 Spline Eaton Posi
Stock Brakes
New Backing Plates
Upgraded Aluminum Cover
** Conversion U-Joint - Stock 3R to 1350 **
Strange S60
Gear Ratio 3.73
35 Spline True Trac
Stock Brakes
New Backing Plates
Strange 12Bolt
Gear Ratio 3.42
Stock Brakes
New Backing Plates
#171
2000 Camaro SS
Strange S60
Gear Ratio 3.73 (or 4.10 still deciding)
35 Spline True Trac
Stock Brakes
New Backing Plates (or not still deciding)
Driveshaft
Shipped to 10512
Strange S60
35 Spline True Trac
Stock Brakes
Driveshaft
Shipped to 10512
