Want a good wideband? (Group Purchase)
#1036
http://plxdevices.com/
This is the most common setup:
http://www.plxdevices.com/products/dm5/afrsmcombo/
Thanks,
Derek
#1039
Hey Derek. I bought one these kits from you awhile back and it had been working great but after removing it from the console, and installing it in a pillar pod it quit working. Methinks I messed up one of the wires. The O2 sensor is fine, can I just purchase the gauge and controller? If so, how much?
Thanks!
Thanks!
#1040
Thanks!
Thanks!
You could purchase another but before doing that check with PLX. Even if the warranty is expired they will fix it. They may charge a couple bucks to do it but it will be cheaper for you in the end.
Sounds to me like it's a simple wiring issue which you may be able to fix yourself.
If you could PM me more details on what the unit is or is not doing I may be able to help as well.
PLX's tech support # is 408-745-7591
Thanks,
Derek
