GB: Interceptor Scan Guages
I'm pretty interested in this group buy but I have a few questions before I commit. I'm interested in the Interceptor gauge to use on a 98 LS1. The main parameters that I would be using from the gauge are oil pressure, transmission temperature, oil temperature and engine coolant temperature.
Which if any of these would I need any sensors or pressure sensors for other than the oil pressure parameter. Will the rest of the parameters be accessed from the OBD port?
Thanks
Ordered last night.
Thanks
Ordered last night.
just got mine in today, install was so easy just plug it in(no 12v power tap needed), and then select what parameters you want to keep track of.
DopeFedZ it does not read oil pressure, and oil temp, but it does read trans temp and coolant temp, on the http://www.aeroforcetech.com/ it says they sell a sensor kits.
So does anyone know if these will work on the LS1 for oil pressure with the additional sending unit?
*EDIT*
Just spoke with Todd at Aeroforce.. They will indeed read oil pressure on the LS1 with the additional sensor..
*EDIT*
