TCI 4L60E Pans
TCI 4L60E Pans
One of the best investments you can make to assure longevity of your automatic transmission is a cast aluminum deep pan. Designed with cooling fins to dissipate heat faster, these pans also provide additional strength and rigidity to the transmission case. No modifications are necessary to the stock dipstick and the pan includes magnetic drain plug, fluid pickup extension, pan gasket and new rail bolts and washers. Holds 2 additional qts.
If you have any questions Email Jon or give us a call toll free - 866-LS1-SPEED
Jon
www.ls1speed.com
866-LS1-SPEED
