LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms & Toe Links
Sponsor
Now shipping!!
Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Delrin Bushings.
Our tubular rear trailing arms will lock in your caster settings, minimize wheel hop and increase traction. Our tubular rear trailing arms are much stronger than the factory's stamped steel arms, these tubular rear trailing arms are constructed from 1.25" x .095" wall DOM tubing and 1/4" CNC laser cut and formed mounting brackets that are fully gusseted to eliminate flex and provide for maximum strength and durability. These tubular rear trailing arms are equipped with greaseable Delrin bushings rather than the soft rubber bushings that come from the factory.
![](http://www.lmperformance.com/images/parts/small-jpg/c10-201-del.jpg)
$157.50. Free shipping!!
http://www.lmperformance.com/53841/119.html
Sponsor
Now shipping!!
Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends.
Lock in your caster settings, minimize wheel hop and increase traction with a set of our spherical rod ended tubular rear trailing arms. Our tubular rear trailing arms are much stronger than the factory's stamped steel arms, these adjustable tubular rear trailing arms are constructed from 1.25" x .095" wall DOM tubing and 1/4" CNC laser cut and formed steel mounting brackets that are fully gusseted to eliminate flex and provide for maximum strength and durability.
These tubular rear trailing arms are equipped with high quality spherical rod ends rather than the soft rubber bushings from the factory. Our spherical rod ended tubular rear trailing arms come equipped with extra high strength, chrome moly spherical rod ends with TeflonŽ self lubricating race. These tubular rear trailing arms weigh in at only 6.80#/pair. They are a 100% bolt-in installation using factory hardware and are available powder coated in your choice of the above colors for an attractive and durable finish.
![](http://www.lmperformance.com/images/parts/small-jpg/c10-203.jpg)
$180.00. Free shipping!!
http://www.lmperformance.com/53842/119.html
Sponsor
Now shipping!!
Spohn Camaro 2010 Tubular Rear Toe Links with Polyurethane Bushings.
Lock in your toe settings, minimize wheel hop and increase traction with a set of our tubular rear toe links. Our tubular rear toe links are much stronger than the factory's stamped steel toe links, these tubular rear toe links are constructed from 1.25" x .095" wall DOM tubing to eliminate flex and are 100% TIG welded to provide for maximum strength and durability. These tubular rear toe links are equipped with fluted and greaseable polyurethane bushings rather than the soft rubber bushings from the factory. They are a 100% bolt-in installation using factory hardware and include the ABS line mounts just like the factory toe links. These tubular rear toe links weigh in at only 4.70#/pair. Available powder coated in your choice of the above colors for an attractive and durable finish.
![](http://www.lmperformance.com/images/parts/small-jpg/c10-601.jpg)
$120.00. Free shipping!!
http://www.lmperformance.com/53846/119.html
Sponsor
Now shipping!!
Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends.
Lock in your toe settings, minimize wheel hop and increase traction with a set of our spherical rod ended tubular rear toe links. Our tubular rear toe links are much stronger than the factory's stamped steel toe links, these adjustable tubular rear toe links are constructed from 1.25" x .095" wall DOM tubing to eliminate flex and are 100% TIG welded to provide for maximum strength and durability. These tubular rear toe links are equipped with high quality spherical rod ends rather than the soft rubber bushings from the factory. Our spherical rod ended tubular rear toe links come equipped with extra high strength, chrome moly spherical rod ends with TeflonŽ self lubricating race. They are a 100% bolt-in installation using factory hardware and include the ABS line mounts just like the factory toe links. These tubular rear toe links weigh in at only 6.40#/pair. Available powder coated in your choice of the above colors for an attractive and durable finish.
![](http://www.lmperformance.com/images/parts/small-jpg/c10-603.jpg)
$224.00. Free shipping!!
http://www.lmperformance.com/53847/119.html
Sponsor
Now Shipping!
Spohn Camaro 2010 Tubular Rear Toe Links with Del-Sphere Pivot Joints.
Lock in your toe settings, minimize wheel hop and increase traction with a set of our Del-Sphere pivot jointed tubular rear toe links. Our tubular rear toe links are much stronger than the factory's stamped steel toe links, these tubular rear toe links are constructed from 1.25" x .095" wall DOM tubing to eliminate flex and provide for maximum strength and durability. These tubular rear toe links are equipped with Del-Sphere pivot joints rather than the soft rubber bushings from the factory. They are a 100% bolt-in installation using factory hardware and include the ABS line mounts just like the factory toe links. These tubular rear toe links weigh in at only 9.10#/pair. Available powder coated in your choice of the above colors for an attractive and durable finish.
![](http://www.lmperformance.com/images/parts/small-jpg/c10-606.jpg)
$254.00. Free shipping
http://www.lmperformance.com/53848/119.html
