Complete 24x Stand Alone Wire Harness Controller Kit with Fuel Pump $999.99
Hey Everyone,
Not sure if a lot of you knew this but we do complete stand alone wire harness kits for the 24x engines.
They Include the following Parts
Custom stand alone Open Loop wiring harness with 4 fuse panel, ALDL connector, Fuel pump relay, 3 wire hook up with 1 fuel pump wire and tach output, main trunk is 50 inches long from rear of engine to PCM connectors, allowing easy installation, a choice of all 3 injector harness leads available.
PCM with a base tune to get you running with other tuning options available.
In-tank electric or in-line fuel pump rated at 255 liters/hour on pump gas up to 585hp, inline fuel filter with AN-6 fittings, 15 feet of -6 high pressure line and fittings. This kit is designed to up fit any GM LS series engine with 24x crank front or rear cam sensor
Options:
DBW Harness Connects to truck 8 pin square - $99.99
4L60E Trans Harness - $89.99
Cam extension wire for LS2 Engines - $55
O2 Sensors - $49.99
Again these are for 24x engines only. We are worrking on our 58x stuff but we don't have it perfected yet.
Options:
O2 Sensors - $49.99
i want tio ues the l92 heads and intake on a lq9 but the throttle body for the l92 set up has only six pins and the motor is a 24x motor.can a 24x harness be made to work with that throttle body?
