****Pavlock performance Cylinder Head Specials****
Our cylinder head department specializes in LSX applications. We offer complete bolt on packages that are sold as a pair and fully assembled ready for your power plant. Our concern is to reach your desired goal, whether it be your weekend racer to your all out LSX DR race heads. ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
-Stage One Port Work
$400.00
-Stage Two Port Work
$800.00-1,200.00
-Valve Job/Valve Grinding (3 Angle Competition Valve Job)
$200.00
-Removing And Installing Seats
$160.00
-Deck Surfacing (Up to .010)
$60.00
-Pressure Testing
$60.00
-Stage One LS1 Cylinder Heads Complete
$899.99
5.3,5.7,6.0 heads (2.00 intake valves)
-Comp 918 valve springs
-Viton valve seals
-Fresh competition valve job
-Lap all valves to ensure proper seal
-Deck surfaced
-Pressure tested
Flow numbers are 280+cfm @ .600 lift. You can expect 20-30rwhp gains with selected camshaft for your application.
-Stage Two LS1 Cylinder Heads Complete
$1,650.00
5.3,5.7,6.0,LS6 heads (larger valves available)
-PRC Dual valve springs .650" lift
-Viton valve seals
-Titanium retainers
-Fresh performance valve job
-Lapped in valves
-Deck surfaced (for desired compression ration)
-Pressure tested
Flow numbers range from 300-310cfm @ .600lift. Heads will also include all flow data for each port. Dyno time has proven 40-50rwhp gains with the right camshaft selection pending on application.
-Stage One LS3 Cylinder Heads Complete
$899.99
***we port your heads***
-Manley valve spring .650" lift
-Viton Valve Seals
-Deck surfacing
-Pressure Testing
Flow numbers are 345+cfm at .600" lift and a 25-35rwhp gain will be expected.
-Stage Two LS3 Cylinder Heads Complete
$1,850.00
***Brand new GM casting***
-Ferrera 2.165" 6000 series one piece Stainless Steel intake valves
-Ferrera 1.600" exhaust valves-PAC Dual Valve Spring .660" lift
-Titanium retainers
-Machined locks and locaters
-Lapped valves
-Pressure tested
-Deck surfaced
Flow numbers are 355-365cfm @ .600 lift. Dyno tests have proven 45-55rwhp gains with a selected camshaft fit for your application. Heads will also include all flow data for each port.
All flow numbers have been acquired by our in house SuperFlow 600 flow bench.
*****There will be a $125.00 core charge if you choose one of our Cylinder Head packages in stock and wish to keep your stock heads****
Any questions feel free to PM me.
Any questions or concerns about the heads or the pricing of the heads you can reach Matt directly in the cylinder head department at (713)504-8746
For questions concerning installation packages and price quotes on other modifications you can reach me directly at (832)492-4375
Our focus is to exceed your expectations. Your satisfaction is our greatest concern! Thanks for checking us out
$400.00
$800.00-1,200.00
$200.00
$160.00
$60.00
-Pressure Testing
$60.00
$899.99
-Viton valve seals
-Deck surfaced
-Pressure tested
$1,650.00
-Viton valve seals
-Titanium retainers
-Lapped in valves
-Pressure tested
$899.99
-Viton Valve Seals
-Deck surfacing
-Pressure Testing
$1,850.00
-Titanium retainers
-Lapped valves
-Pressure tested
-Deck surfaced
