AP-Engineering 409
Originally Posted by CANNIBAL
Is that an iron block?
YOu can see from the first words of his post that this is an ironblock! AWESOME PRICE NO DOUBT!!!! :judge
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
PSJ Wannabe & Attention Whore
jz....same pricing if its a 382 or 408 with the eagle kit and an off the shelf piston.
nitrousboyWS6 - I can do a long block 409 for 9500, WITHOUT cores.
It includes :
6.0 block
callies crank
callies rods
diamond pistons
diamond rings
m77 bearings
custom hydro cam
new lifters
trend pushrods
ported ls6 pump
MLS head gaskets
ARP head studs
adjustable timing set with jwiss chain
ported 6.0 heads with 315 cfm @ 600 flow
full blueprinting
balanced
long block assembly
Also included :
oil pan gasket
front cover gasket
rear cover gasket
both front and rear crank seals
tool steel pins
Call for details
It includes :
6.0 block
callies crank
callies rods
diamond pistons
diamond rings
m77 bearings
custom hydro cam
new lifters
trend pushrods
ported ls6 pump
MLS head gaskets
ARP head studs
full blueprinting
balanced
long block assembly
Also included :
oil pan gasket
front cover gasket
rear cover gasket
tool steel pins
Call for details
