Springing into savings at VFN!!
#882
My car was a victim of Arson and I'm in need of a really good deal on this hood. My whole front end is being stripped down and sandblasted then reassembled. PLEASE HELP
#883
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/1080x720/fb_img_1505785821237_790a1dd66e70b4f21659b996cdd6f6350cb3ab66.jpg)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/691x690/fb_img_1501867017607_65909a68b4cf050f09d8b778522fe46bf0cdcd1b.jpg)
#888
Perfect, are the mesh grille's available in black or will I need to paint them? Also, my friend bought a hood from a different manufacturer which had a gel coat on it where the paint wouldn't stick and it had to be sanded off. I know VFN makes a good product but I just want to know how it's finished. My next purchase is going to be a smoothie q hood.
#889
You will need to paint them. They are a silver mesh
With our hoods, you will need to block it prior to painting. The gelcoat is a protective surface and no, the paint won't stick to it ~ We recommend blocking it down entirely - then using an epoxy primer to "build it back up". You'll want to do this process twice to give the hood it's flattest working surface. Then you can spray with paint
Sounds great! You'll love it - they look mean as hell
Thank you very much
Jean
#893
So with $50 in packaging, you'll total out to $845 before freight
This breaks down to $370 for the non extended Camaro pin on
and $425 for the Nova Sunoco.
Freight we would do a prepaid once the order is ready
To keep you at the carrier's minimum we do recommend delivery into a commercial location
This will put you at $170 for both being shipped
Carrier will make a home delivery but they charge more - will push you up to $260 instead
Thanks!
jean
#898
With these discounts running already - there are no additional discounts or codes that will apply
Most hoods on this gp are an average of $70 off listed retail price
$535 on the 3" SS hood (retail $615)
Ultra Z - $480 - Retail $535
Dash would run $245
Thank you very much!
J
