PCMCalibrators offer PCM Servicing and Tuning
We have been very busy and we are getting behind on a few orders. Thanks everyone for your patience
I will be out for a week this coming up month for CNG training. I will keep everyone updated. I am sure it will make our orders get behind again
$200 Startup tune: This is for bolt-ons, VATS Shut off, stock vehicles, for most NA combination to get you up and running safe allowing you to sart tuning or make it to the dyno safely.
Please email us for a price for segment swaps and parameters that other tuning software packages can't adjust. Example: 12V input for AC activation or E-Fans. At times we may do them cheaper. Please contact us for details
Starter Tunes: Our "Starter Tunes" start at $250. These come with full support. This is our biggest seller. We will get you a good tune and help you dial it in for you preferences. Example: Not everyone likes the same shift duration at the same throttle input or the same throttle responce. I have actually had to make shifts softer and throttles not so touchy and other guys want that snappy throttle and crisp/hard shift at low throttle input
Price update
Minor Tunes starting at $85 for most PCM's
Minor Tune: Speedometer Recalibration for Different Gear Ratios or VATS disabled
Basic Tunes starting at $200 for most PCM's
Basic Tune: Changing Injector size, Rev Limiter, Shift Points
Custom Calibrations starting at $425 for most PCM's
Do you have a conversion? Have you swapped in a GM Engine into another brand of vehicle? Need a Standalone setup? Need a segment swap? Running a 4L80E now and have 4L60E code? How about getting your fuel gauge operating correctly? Want your PCM to control your AC? We do it all!!!
Call or email us for prices on Forced Induction Tunes
We offer GM OBD I and OBD II
Tuning for most GM cars and trucks from 1985 to 2013 Most 4 cylinder, Inline 6, V6 and V8.
