CNC LS2 cylinder heads
LS1Tech Premium Sponsor
X88958765
Unbelievable performance from fully CNC ported cylinder heads from SDPC...some of the best low and mid-lift numbers we have ever seen from a stock size valve. These heads will flow over 200cfm at 0.300" lift and 285+ at 0.500". Fully assembled with 2.00" solid stem intake, and 1.550" solid stem exhaust valves and new .570 lift valve springs. These heads have a 65cc combustion chamber. Care must be taken to check pushrod length and proper intake installation when using these cylinder heads. The heads are priced at $499.95 each!
Lift Intake Flow Exhaust Flow
.200" 147 cfm 115 cfm
.300" 204 cfm 148 cfm
.400" 251 cfm 189 cfm
.500" 289 cfm 200 cfm
.600" 307 cfm 220 cfm
Available for purchase on line at SDPC.
http://sdparts.com/details/scoggin-d...nter/x88958765
__________________
Tim Cooks
Scoggin Dickey Parts Center
806-798-4000 ext 352
“Your Source For Performance”
Tim Cooks
![](https://ls1tech.com/forums/signaturepics/sigpic76327_2.gif)
X88958765
