C5R 427 Longblock- 8.29@163mph @ 3200lbs NATURALLY ASPIRATED!!!!
Old 09-09-2011, 02:45 PM
Ron@Vengeance's Avatar
Default C5R 427 Longblock- 8.29@163mph @ 3200lbs NATURALLY ASPIRATED!!!!
This engine currently powers the 2nd quickest/fastest Naturally aspirated LS F body in the world. This combo runs consistent 8.50s@160mph in 4000DA and has run a best of 8.29@163mph in good air...
Video of several 8.xx passes..
Info:
C5R Block
DragonSlayer 4.00 Crank
BME Connecting Rods
Diamond Pistons
Calico Main & Rod Bearings
All Machine work/Assembly performed by Proline Race Engines
C5R Cylinder Heads
2.250 Intake Valves
1.600 Exhaust Valves
Nextek Springs
Jesel Solid Lifters
Custom Spec Solid Roller Camshaft
Hardened Pushrods
ARP Top to bottom
Includes Beck mechanical Sheet metal Intake
Compression/camshaft specifications/details will be provided to the buyer.
Engine will include the following items:
Block/Crank/Rods/Pistons/Rings/Bearings
Camshaft/Lifters/Pushrods
Cylinder Heads/Springs/Valves
Head Gaskets/Head Studs
Beck Sheetmetal Intake
Rear Cover
Not Included:
Oil Pan/Oiling System
Ignition
Rockers
Longblock has 25 passes on it since it was freshened last. No issues. Still in the car. Can hear run. Can watch it go down the track.
Reason for selling:
Owner is getting out of the all motor game and going a different direction....
Please call/PM if interested. Specifications will NOT be given to tire kickers
$22,000.00
Old 09-10-2011, 08:34 PM
scphilli's Avatar
$22K cash will NOT be given to used motor specification hoarders!
Old 09-12-2011, 11:09 AM
Nevermind....
Quick Reply: C5R 427 Longblock- 8.29@163mph @ 3200lbs NATURALLY ASPIRATED!!!!
