Ported FAST 102's from Peak Speed Shop!
$1,099.99 for ported FAST102 ($849.99 if unported). Porting that model generally gets an additional 12 rwhp / 14 rwtq. If you have an LS2, no additional parts are required. If you have an LS1 or LS6, you will need to order a fuel rail kit and an adapter for your 78mm throttle body. Or, upgrade to the LS2 90mm throttle body or a 102mm throttle body.
Feel free to call if you have questions. 719-651-1952 or go to our website at http://www.peakspeedshop.com/. You can order everything right from our website.
$1,099.99 - Ported FAST102 for LS6 (#146302)
$ 224.99 - OEM style Fuel Rail kit for LS6 (#146021)
$ 24.07 - Port Seal Replacement Set - LS6
$ 54.95 - Throttle body adapter plate kit, 78mm to 102mm.
$1,404 TOTAL
Other options for upgrading from your 78mm LS6 throttle body:
$ 375.00 - Ported 90mm LS2 throttle body
$ 595.00 - Nick Williams 102mm DBW throttle body
$ 54.95 - Throttle body harness - connects these throttle bodies into LS6 wiring harness.
You can find out more information and order on our website at: http://www.peakspeedshop.com/FAST.php
$1,404 TOTAL
