Ported Intake Manifolds and Throttle Bodies in stock!
#46
I have done my research and decided to go with LS2 set up but do need some help so to do the switch I need
1) LS2 fuel rails
2) LS2 injectors cnt use my LS1 injectors?
3) Can I use a aftermarket LS2 92mm TB? Do I need any adapters? Can't find a LS2 90mm
4)Adapters from my LS1 harness to LS2 fuel injectors
5)MAP extension wire
Anything I'm missing or something I dnt need I got a most of the parts put together for around 850
Thnks PeakSpeed Shop For any info u can give me
1) LS2 fuel rails
#47
1) LS2 fuel rails
1) LS2 fuel rails
Yes, you can use an aftermarket LS2 90mm throttle body. You will need the wiring adapter for the LS2 throttle body.
We have many of the parts you need. Let us know what you still need and we can give you a quote.
#59
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
