Erl sleeved blocks and short blocks in stock!!!!!!!!!
We have 3 different sleeve packages depending on your application.
We have the following sleeving options:
- ERL Dry Sleeve
- ERL Superdeck 1 "4 bolt"
- ERL Superdeck 1 "6 bolt"
We have the following sleeved blocks in stock right now with a rough bore of just under 4.125.
(12) - ERL Superdeck 1 "6 bolt" using 5.3's, LS2's and LS3 blocks.
(6) - ERL Superdeck 1 "4 bolt" using 5.3's, LS2's, LS3's and LS7 blocks.
(5) - ERL Dry Sleeve using LS2's and LS3 blocks.
You can send in your block as a core exchange for one we have on the shelf, you can send in yours for us to sleeve or you can purchase one outright if you don't have a core. Either way we have them sleeved up already and just need to do a final cylinder to most of them.
We can also turn these into any of our short block packages as well.
Visit our website at https://www.erlperformance.com or give us a call at 812-945-3434 to check on availability of these in stock.
- ERL Dry Sleeve
