600+HP for long block and NOS kit with 1YR warranty $5999
LS1 tech special for your power needs.
TMS Long block including the following:
GM 6.0 short block Gen III LQ9 (Gen IV available at an addl cost)
11:1 Pump gas friendly build
King Racing main/rod bearings
Durabond cam bearings
Diamon Racing 2618 Forged pistons 4.030" built specifically for TMS with lowered ringlands, additional supports and much more
TMS or Eagle H-beam connecting rods
ARP 8740 rod bolts
TMS 64CC CNC ported 799 LS2 heads
Carbon steel intake valves 2.00"
Stainless steel exhaust valves 1.57"
TMS custom ground camshaft
Dual valve springs good to .675"
Titanium retainers
Chromoly spring locators
Viton high lift seals
Chromoly Pushrods
Melling select high pressure oil pump
GM MLS head gaskets
TMS 8740 head STUDS (12PT)
LS7 high rev lifters
LS2 Timing set
LS2 Lifter treys
BLUEPRINTED GM block reman
Balanced and polished GM crankshaft reman
Professional assembly in house at Thompson Motorsports
12 MONTH UNLIMITED MILEAGE WARRANTY on motor
AND:
Nos sniper kit with everything you need for 75/100/125 shot. This combo will make well over 600HP pump gas friendly. Put your F-body or Y body in the 10s for only $5999 and keep your warranty.
Make sure and let us know your a tech member for your discount.
972-853-0518
ARP 8740 rod bolts
Titanium retainers
Chromoly Pushrods
GM MLS head gaskets
LS2 Timing set
LS2 Lifter treys
AND:
972-853-0518
