LS3 Small Bore Heads - Manley Pushrods - ARP - and more inside!!!
BSP LS3 Small Bore Heads
Ballistic Speed Parts LS3 Small Bore cylinder heads are a direct fit to your stock bore LS1 or LS6 engine. We’ve spent over 2 years developing the ultimate cylinder heads for LS1/LS6/LS2 Engines using GM’s outstanding LS3 cylinder head as our platform. We are proud to offer our heads in 2 Stages that will allow you to bolt on up to 55HP.
Our cylinder heads also feature high quality, race proven, stainless steel intake and exhaust valves from Ferrea Racing Components.
Stage 1 (As Cast):
• 326 cfm of airflow
• Over 48HP Gain! (On stock cube LS1 346)
• Intake Port Volume: 255cc
Stage 2 (CNC Ported):
• 350 cfm of airflow
• Over 55HP Gain! (On stock cube LS1 346)
• Intake Port Volume: 270cc
Flow Sheets and Info: http://ballisticspeedparts.com/shop/...6-ls2-engines/
![](http://ballisticspeedparts.com/wp-content/uploads/2011/08/BSP-LS3-1-LS3-2-Cylinder-Heads-300x300.png)
Manley Pushrods From $119.99
Manley pushrods are manufactured from heavy duty 4130 Chrome Moly and are heat treated and feature a black oxide finish.
Available in 5/16" and 3/8" Diameters:
![](http://cdn-bsp-2.ballis.tc/wp-content/uploads/manley-pushrods-for-chevy-lsx-1-300x300.jpg)
ARP Hardware
ARP Head Studs and Head Bolts...From $109.99
http://ballisticspeedparts.com/shop/...ry/studsbolts/
![](http://cdn-bsp-2.ballis.tc/wp-content/uploads/ARP-Head-Stud-Kit-234-4316-%E2%80%93-LS-Engines-Pre-2004-300x300.jpg)
Gasket Kits
All kits include factory GM gaskets and bolts with options for ARP hardware if needed.
Cam Install Gasket Kit: $54.95
http://ballisticspeedparts.com/shop/...package-deals/
Basic Head Install Gasket Kit: From $87.99
Deluxe Head Install Gasket Kit: From $178.92
![](http://cdn-bsp-2.ballis.tc/wp-content/uploads/bsp-deluxe-head-install-and-bolt-kit-300x300.png)
BSP 4" High Flow MAF Housing $109.95
http://ballisticspeedparts.com/shop/...s-air-housing/
![](http://cdn-bsp-2.ballis.tc/wp-content/uploads/BSP-MAF-100-400x400.png)
Stage 1 (As Cast):
- 5/16 Diameter (fit cathederal and rectangle port heads, recommended for street/strip NA applications)
- 3/8" Diameter (fit cathedral port heads with slight modifictaion, fit rectangle port heads with no modification, recommended for max effort NA and power adder applications)
ARP Hardware
Gasket Kits
Here is a thread with some great info on our LS3 Small Bore Heads, including dyno results from another forum member.
https://ls1tech.com/forums/dynamomet...test-mule.html
Feel free to PM me with any questions.
Thanks!
Thanks!
