Stroker motors new with CNC ported RHS heads starting at $6998.00 with 1 yr warranty
Thompson Motorsports is offering for the next few days ONLY (Ends 6PM CST Friday May 16th) our stroker motors with RHS CNC ported heads on sale.
What do you get?
Your choice of RHS CNC ported heads 232cc or 250cc on top of our long block.
Blueprinted GM block
All TMS motors will include the following:
Thompson Motorsports 4340 stroker crankshaft angle weight reduction drilled, Gun barrel drilled and Key ways
Thompson Motorsports 4340 forged H-beam connecting rods 6.125" with ARP rod bolts
Diamond forged pistons -2cc or -15cc (-10cc on 383)
Dual valve springs with titanium retainers
Thompson Motorsports billet cam (about 60 cams to choose from call to spec yours)
Chromoly pushrods
Thompson Motorsports head stud set
GMPP MLS head gaskets
Melling select high pressure pump
GM rocker Assembly
TMS Aftermarket ls7 lifters
ls2 timing set
Thompson Motorsports professional assembly and 12month unlimited mileage warranty
PRICING:
383CI Iron long block $6998.00
383CI Aluminum long block $7298
402 OR 408CI Iron block $7298
402CI Aluminum LS2 $7898
418 Aluminum LS3 $8298
427 LSx $10298.00
427 LS7 wet sump $10998.00
Call to place your order 972-853-0518. You must call before friday and ask for Kyle to receive the pricing above.
Aluminum LS3 block is blueprinted GM new
Aluminum LS2 block is blueprinted GM new
LSx block is blueprinted GM new
LM7 383 is blurprinted GM core
LQ9 402 and 408 is blueprinted GM core
L33 383 is blueprinted GM core
What do you get?
Chromoly pushrods
GM rocker Assembly
ls2 timing set
PRICING:
427 LSx $10298.00
