AEM Infinity Stand Alone for LS Engines - AEM Gauges
Closed ex-Sponsor Account
We are running a special on AEM Infinity systems for the LS engine family.
The AEM Infinity will rival any of the "top" engine management systems out right now.
Call us for best pricing and mention this ad for your LS1Tech discount.
Our website does not reflect the LS1Tech Discount.
Each Infinity ECU includes ignition coil outputs and injector drivers equivalent to its name. The Infinity’s airflow-based tuning models simplify start up and speed up the tuning process by eliminating many of the lookup and trim tables (Correction Tables) necessary in previous generation ECUs. For a limited time, all Infinity systems come fully enabled without the need for feature add-on purchases. Combined with AEM’s industry leading after-purchase support system, including free technical support, the Infinity is the ultimate engine control solution for both professional race teams and weekend track cars.
•Airflow model based (VE) tuning
•ECU Set Up Wizard simplifies start up
•Flex fuel compatible
•Multi fuel capable
•Drive by wire
•Variable valve control
•Multiple boost control strategies
•Nitrous control
•Map switching
•Dual internal Lambda controllers
•Dual knock sensing circuits
•Data logging up to 64GB, up to 100 channels at 1KHz
•Outputs to 3rd party dashes and data loggers
•Industry leading data transfer speed (up to 480Mb/sec)
•Integrated engine protection strategies
•Sealed enclosure and IP67 rated comms ports
This comprehensive wiring harness allows racers to easily and affordably integrate the Infinity Programmable ECU onto their 24x LS race engine by plugging into the factory sub harnesses and using factory sensors.
An integrated fuse and relay panel includes five relays and seven fuses that delivers safer power distribution, engine circuit protection, and easier integration of additional features. Relays with flying leads are included for the fuel pump and fans. The housing is weather resistant and panel lid is weatherproof for added protection.
The harness utilizes Automotive-grade, color-coded wiring and the timing inputs (cam and crank sensors) are shielded for optimum performance. Water and shock-proof factory connectors for the sensors are used throughout the harness, as well as Deutsch connectors for auxiliary components. The IP67-rated ECU connectors are designed to mate with AEM's Infinity-8 or Infinity-10 ECU and connections for dual wideband O2 sensors, VSS, Knock, and CAN are integrated into the harness.
AEM Infinity GM LS 24x Layover Harness Features (PN 30-3532):
•Plugs into factory sub harnesses and uses factory sensors for easy integration
•Integrated, weather-resistant fuse & relay panel (7 fuses and 5 relays) for optimum circuit protection
•Shielded cam/crank inputs
•Automotive-grade, color-coded wiring
•High temp flex loom
•Waterproof & shockproof factory sensor connectors
•Deutsch connectors for auxiliary components
•Individual coil sub harnesses not included
AEM Infinity GM LS 24x Layover Harness Connectors:
•Wideband O2 1 & 2
•Alternator
•AEMnet
•Crank Position Sensor
•Cam Position Sensor
•Coils Bank 1 & 2
•Engine Coolant Temp
•Idle Air Control Valve (4-wire stepper motor)
•Inlet Air Temperature
•Injectors 1-8
•Knock Sensor
•MAF Sensor
•MAP Sensor
•Oil Pressure Switch
•Reverse Lock Out
•TPS
•Vehicle Speed Sensor
•Radiator Fans 1 & 2 (12" flying lead)
•Fuel Pump (12" flying lead)
Check here for AEM Infinity systems and accessories.
http://www.sho-mespeed.com/cat3/category/942-aem
•Multi fuel capable
•Drive by wire
•Nitrous control
•Map switching
•Wideband O2 1 & 2
•Alternator
•AEMnet
•Coils Bank 1 & 2
•Injectors 1-8
•Knock Sensor
•MAF Sensor
•MAP Sensor
•Reverse Lock Out
•TPS
