Evans LS1 Water Pump Special
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Evans Cooling Systems Inc has just released More of there highflow LS1-6 water pumps. We finally got some new castings from GM.
The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficiency in modified LS1 Corvettes, Camano’s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce parasitic horsepower loss at high RPM. A new serpentine belt is required.
Evans complete new water pump with billet pulley $469.95 for Corvettes
Evans complete new water pump with billet pulley $469.95 for F-Bodies
Evans complete new water pump with billet pulley $469.95 for Trucks
Can even convert your truck pump to a car casting to work with a LS6 or LSX intake.
Rebuilt GM pump with all new internals $399.95 and $125core charge
Add $125 for ceramic thermal coating-for extra heat dissipation and a little bling
Evans superflow 160* or 180*T-Stat $59.95 FREE With purchase of a pump
Goodyear serpentine belt $49.95 with purchase
Evans NPG coolant $22.50 a gallon with purchase
Evans NPG+ coolant $22.50 a gallon with purchase
Also Evans new NPG R race coolant in stock $19.50 a gallon with purchase
Or buy by the case(4)
Have a good day Nate
