98-05 Custom Valve covers GP $280
#33
nate, could you send me a price for the tall covers with a push in oil cap please? i'm guessing stock length plug wires wont work with the taller covers and coils mounted on them? i was planning on moving the coils but looking at options.
#35
Nate,
How much for a set of tall covers, powder coated red anaodized, with polished billet relocation brackets & a screw on filter? (& are there any purdy filter options?) Also, do you sell the longer plug wires?
Thanks
Mark
Thanks
Mark
#36
Nate, I am interested in a set of sheetmetal valve covers for my 98 model, but i am installing a set of 99 and up (centerbolt) heads on my car. will my coils bolt into the brackets you put on these valvecovers, and what to do with the pvc system,delete it or what, also I am putting shaft mounted rockers on also so will I need the tall ones or will the short ones work. Thanks
#37
Valve covers
You will need the tall center bolt covers for shaft rockers. If you get the complete setup your coils will bolt on the billet coil brackets. As far as PCV people have gone several ways we can add AN fittings to the covers so you can make a PCV system or just simple breathers in the covers.
Thanks Nate
Thanks Nate
#39
Nate,
Here is a pic of the TB Jantzer made for me. Let me know if you can get close to this with the color on the valve covers. Not sure how he made this color. He called it anaodized red. Maybe he hit it with red & then put a coat of translucent red over the top. Not sure.
Anyway, let me know what a set of the fabbed covers in this color with the coil pack bungs would cost. And I'll want the polished coil packs & breathers. (you do put a breather on both covers, yes?
In the meantime I'll try to find a set of longer wires. Do you know the length?
Thanks
Mark
Thanks
Mark
