NX-Cam Shaft Clearence Sell!!!!
stage 1
BUMPSTICK CAM SHAFT STAGE 1. SEAT 268-276, @50 212-218, LOBE LIFT
.312-.312, VALVE LIFT .530-.530 C/L 114'
Requires new valve springs ( COMP 26915-16)
stage 2
BUMPSTICK CAMSHAFT STAGE 2. SEAT 280-286, @50 224.228, LOBE LIFT
.335-.330, VALVE LIFT .570-.560, C/L 114' Requires new
valve springs ( COMP 26915-16), and Computer Mods.
stage 3
BUMPSTICK CAMSHAFT SATGE 3. SEAT 292-298, @50 235-239, LOBE LIFT
.353-.341, VALVE LIFT .600-.580. C/L 112'
Requires new valve springs ( COMP 26915-16), Computer Mods, Large Injectors,
Pistons with Valve Relief.
We are trying to clearence these cam shafts out..
They are 275.00 each.
Thanks
Dave
stage 2
stage 3
Thanks
Dave
Dave, could you do a special on:
Part Number: NX-109
NX MAF plate system upgrade
If you currently own an NX kit you can easily upgrade to the new MAF kit.
The upgrade kit will include both MAF halves, 4 hoses, 2 T-fittings, 4 custom 90' fittings and jets.
Please
Part Number: NX-109
Please
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
