How about a Wideband GP?
Originally Posted by Flareside
I called Innovate today. The next batch of LC-1s will ship next week, so I ordered one. They're going for $199.
Bill
Originally Posted by matts22
Do these prices include shipping? If not, how much would the total be for an LM-1 to 64759? Thanks!
Thanks,
Originally Posted by Chris@AP-Engineering
I can do the LC-1's for $185. They are currently out of them but, they said that they should be ready to ship within a week or so.
Thanks,
Thanks,
I'm in, shipping to 79762 how do i order?
Originally Posted by ace68
I have flashscan and just need a basic sensor kit, no display and stuff just a ox with a annolg output who makes something like that?
Bill
#39
Both the LM-1 and the LC-1 will work with FlashScan. They both have 2 programmable outputs. I have the LM-1 (purchased on a previous AP GP) and have it working with FlashScan.
All you have to do is set up one of the outputs to be 0 volts = 10:1 and 5 volts = 20:1. This is range that the PLX devices WB outputs. Wire up the connector to the Aux output on the LM-1/LC-1 and plug it into the FlashScan dongle. Next select either the PID AD1 or AD2 for the external voltage that you setup on the LM-1/LC-1 and then select either the PID AFR_PLX1 or AFR_PLX2. I hooked mine up this way and it worked first try. I also added a gauge to the "A" dashboard so that I can see what is happening as well as log the data.
I hope that this helps.
