*Special* TTP Stage 3, 3R, 4R Heads/Cam Package Installations
TTP Stage 3 Equalizer Heads/Cam Package
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.3 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
SVO 30lb Injectors
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4999.95 Turn-Key (Add $100 for Corvettes)
Options:
LSX 90mm Port Matched Intake Manifold with FAST or NW 90mm Throttle Body - $1250 Installed
Meziere Electric Water Pump with Relay - $600 Installed
Kooks 1 3/4" LTs with 3" ORY - $1000 Installed (Add $260 for Cats) (Add $200 for Corvettes with X-Pipe)
TTP Stage 3 Equalizer Package Results:
This package just made 482rwhp/418rwtq through a 2002 Camaro M6 with LSX 90mm, Mez Electric W/Pump, 4.10 gears, SLP Loudmouth, Kooks 1 3/4" LTs, ORY.
This package also made 474rwhp/429rwtq through a 2003 Z06 with Stock LS6 Intake, Stock Throttle Body, Mez Elec Water Pump, Borla Stingers, Kooks 1 3/4" with OR X-Pipe.
TTP Stage 3R Equalizer Heads/Cam Package
TTP AFR 225cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP (Milled to 63cc)
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
$5799.95 Turn-Key (Add $100 for Corvettes)
We have everything in stock ready to schedule appointments immediately.
Options:
We just finished up results on a 2002 Z06. Here is the mods list and power from the 3R package:
TTP Stage 3R Equalizer Package, LSX 90mm Intake, NW 90mm T/B, Mez Electric Water Pump, ASP U/D Pulley -- Full Belts, TPIS LTs with CATS (Hurting the car greatly), 19" IForged Rims
491rwhp/421.3rwtq
TTP Stage 4R Equalizer Heads/Cam Package F-Body
TTP Equalizer Version 3.1 Camshaft
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
$5999.95 Turn-Key (Add $100 for Corvettes)
Options:
This package just put down a record breaking 505rwhp/436rwtq in a 1998 Camaro with a LSX 90mm, Mez Elec Water Pump, Kooks 1 3/4 to 1 7/8 LTs, true dual 2.5 system. This was done through a power robbing 9", spool, 4.10 gears, 35 spline axles.
![](http://www.ttperformance.net/dyno/petebspz28.gif)
Note: The red line is the customer's old heads/cam package. The blue is the TTP Stage 4R Package.
We have appointments available immediately. Give us a call to schedule in 973-365-2270.
Thanks,
Matt
SVO 30lb Injectors
(2x) AIR Gaskets
Installation
Options:
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
Options:
491rwhp/421.3rwtq
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
Options:
Thanks,
Matt
