new rear end GP?
new rear end GP?
it seems like everyone wants a new 12 bolt or 9 inch rear, but the thought of paying 2000 dollars for one doesnt appeal to them. would any of the sponsors consider doing a GP on new rears? sry if this has recently been done, but i searched and it seemed none of them never succeded. i'm sure lots of people would participate if a considerable amount was knocked off the price.
Originally Posted by red1999z28
I broke mine last night....I want a Billingsley Racing 9" Street Package But I don't have the money just yet.
We have the Strange 12 bolts on sale but there is no way to get them for less than $2000.
Sale pricing through July 5th is -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2239.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2239.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
I'm interested in a strong 9" / 12 bolt rearend. Please email me a price on the strange. Also, which rearend would be the best for an A4, and 3.73 gear. Thanks..
King of Pigskin Knowledge
I'm in if anything happens, I doubt it will though. Seems all the prices are about the same. I need a 9" within the next few weeks. I cringe at the thought of what these rears go for. It kept me from buying one on my IROC at all, and I've postponed getting one for this car about as long as I can. The 10 bolt is such an inadequate part to put in these cars in the first place and $2000-2500+ for a rearend just blows.
