Forged 347ci Shortblocks
We have two Forged 347ci shortblocks that we can have ready to go in about a week, all parts are in stock
Forged 347
LS1 or LS6 5.7L Alum. Block
Stock Crank Polished and Magnafluxed
Callies LS1 Rods
Diamond Pistons 3.905 Flat Tops -2cc Valve Reliefs
Diamond Pro-Select Rings
Federal Mogul Main Bearings
Federal Mogul Rod Bearings
Clevite Cam Bearings
ARP Main Studs
Short block fully balanced, blueprinted and assembled
Price $2799.99 no core or core charge(plus shipping)
Full 347 Long Block for $4899.99(plus shipping)
includes everything above plus
Custom Cam
LS6 Ported oil pump
Rollmaster Double Adj timing chain
Comp Cams Lifters(850-16's)
Stage 2 Heads
Assembled
Long block will take a little longer due to custom cam order.
Forged 347
Callies LS1 Rods
ARP Main Studs
Custom Cam
LS6 Ported oil pump
Stage 2 Heads
Assembled
Originally Posted by RaRe99SS
how much Hp you think youd get outta this setup?
Shortblock
for the 347ci without the heads it would be $3699.99
we can do a dished piston for the same price as long as it is an off the shelf piston. Diamond has a -8.6cc boost piston that will put you at about 9.3:1 with a stock LS1 head
for a 370ci setup it would run just $200.00 more(not counting heads), we would use a -15cc piston and get you in the 9.4:1 compression range with a stock LS1 head
Originally Posted by SSPEEDY
how many liters does a 370 cubic inch bump you up to? Goofy question but very curious.
Man. This is a good deal. I was told I have a two month wait. Hell I should just ship you my long block and get it done. LOL Its never ends with you guys. Keep pumping out the good deals.
possibly interested in one of these motors with heads. but i am going solid roller. i have oil pump, timing set, and morel lifters already. i would need lifter bushings installed, and 1/2" head studs. as well as all solid roller valvetrain. and t&d rocker arms. can you work something up for that?
Possibly interested in this combo:
Forged 347
Callies LS1 Rods
ARP Main Studs
can you change it to boost friendly pistons? and will you be going to the BG event (north vs South)? I would be willing to pick it up there to save shipping.
Forged 347
Callies LS1 Rods
ARP Main Studs
