Interceptor OBD-II Scan Gauge
A new product we sell here at FLP is the Interceptor OBD-II Scan Gauge. It works much like a Scanmaster but fits in a 2 1/16" gauge pod. This item normally retails for $219.99 but we are going to offer it at a introductory price of $199.99 till Saturday August 6th. They are offered in three different colors White/Black, Blue/Black, and Red/Black. They offer two different gauge faces in Black and White.
![](http://www.aeroforcetech.com/images/redblackwhitefacethumb3.jpg)
The Interceptor is capable of displaying the following parameters, two at a time, at a rate of approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, theInterceptor will recognize this and make it available for display.
-RPM
-MPH
-Intake Air Temperature
-Mass Air Flow Sensor Frequency
-Mass Air Flow Sensor (lb/min.)
-Engine Coolant Temperature
-Injector Pulse Width (bank 1 and 2 if supported)
-Long Term Fuel Trim (bank 1 and 2 if supported)
-Short Term Fuel Trim (bank 1 and 2 if supported)
-O2 Sensor Voltage (bank 1 and 2 if supported)
-Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
-Ignition Advance
-Knock Retard
-Engine Run Time
-Battery Voltage
-Transmission Temperature
-Idle air Control Counts
-Throttle Position Percentage
-Throttle Position Voltage
-Engine Load
-Oil pressure (some 8 cylinder engines)
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 50% and engine load exceeds 65%. Approximately 35-40 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
Another menu option offers the ability to swap the foreground and backround colors of the display (to be shown soon in the IMAGES section of this site). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
Lastly, DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.
Power is supplied to the unit by the OBD2 port, so no additional wiring is needed, simply plug-and-play!
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously. Please note that these dual gauges are designed to work in tandem and not separately. They will not function properly apart.
Please call to order at 877-FLP-2WIN or 630-820-9294 or it can be ordered off our website at https://www.flp2win.com/store/produc...7cf9e3a2d5fbfc .
![](http://www.aeroforcetech.com/sitebuilder/images/black_blueinvertwebpic-150x150.jpg)
![](http://www.aeroforcetech.com/sitebuilder/images/black_whiteinvertwebpic2-150x150.jpg)
-RPM
-MPH
-Ignition Advance
-Knock Retard
-Engine Run Time
-Battery Voltage
-Engine Load
