C6 O2 Extention Harnesses - Silver/Teflon/Fiberglass
Tired of bulky extenders which turn to mush when placed in close proximity to aftermarket headers. Have a turbo system that keeps roasting your extenders?
Please see our new C6 O2 extension harnesses which feature silver/Teflon wire (O2 type wire) and black fiberglass 1200F loom:
Front O2 extenders
![](http://www.racetronix.com/product/RX-O2EXT/RX-O2EXT-4T-24.jpg)
Rear O2 extenders
![](http://www.racetronix.com/product/RX-O2EXT/RX-O2EXT-4S2-24.jpg)
This harness allows the oxygen sensor to be relocated up to 24 inches from its factory location. This harness is perfect for the installation of headers which require the sensor be moved further downstream. The high-temperature rated Teflon wire and fiberglass loom allow the harness to be placed close to the exhaust manifolds without worry of being damaged. The harness's small 1/4" outer diameter allows it to be routed in tight areas while providing increased clearance from hot or moving components (i.e. turbo systems). The loom's black outer jacket provides for a low-key appearance in your engine compartment.
KEY FEATURES:
- Fully Plug and Play with the factory harness & sensors
- Military spec. high-temperature Teflon wire (same type used on oxygen sensors)
- High-temperature (1200F) heat-treated black fiberglass 1/4" protective loom (less bulk and superior to plastic loom)
- All connections crimped and soldered
Available through your local Racetronix dealer / LS1 sponsor.
Thank you
Front O2 extenders
Rear O2 extenders
KEY FEATURES:
Thank you
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
