Nitrous Outlet LS1 Plate system...
This is a multi-port discharge plate.This gives you a larger cover area for your nitrous stream which will eliminate distribution problems seen in most ls1/Lt1 based plate applications.
These are introductry prices.So pricing may change in the future.
The COMPLETE SYSTEM will come complete with a 10lb bottle with high flow 45 valve,Microswitch,wiring harness and relay,main feed line,stainless steal quick release bottle brackets,300 Hp lifetime warrenty solenoids,Nitrous Plate,oil ring gasket,throttle linkage spacer,jetting from 35-150,hoses,bolts,and fittings. All this for 650.00
CONVERSION KIT- Comes with the plate,Oil ring gasket,Throttle linkage spacer,Bolts,Fittings and jets Cost...225.00
These should be ready to ship before the end of this month(September).
We are now taking orders.These are not on the web site at this time so you will need to call in at 1-866-648-7637
Thanks
Dave
