Combination motorsports Forged 347
I have two friends ordering this motor and get a good deal if I get at least one more.. PM ME for the price its less than u would think and If you would like to see some of the work they have done Look at Parish's truck. You can PM me or call cmotorsports and ask for Dave
http://www.cmotorsports.com
Callies Dragon Slayer 3.622" Stroke Crankshaft
Callies Compstar Forged H-Beam 6.125" LS1 Connecting Rod
Mahle Forged Pistons Powerpak 3.905" Bore, 3.622" Stroke,6.125" Rod -2cc Valve Relief
Cleveite (H) series rod bearing set 'standard' Poly Dyn Coated
Clevite Standard LS1 Main Bearings H series
ARP LS1 Main Stud Kit
Balancing Rotating Assembly
Hone w/torque plates
Square Deck Setting the Deck Height of the Engine Block in Relation to the
Main Line
Pin Fit Pin fitting of Rods, and Pistons
LS1 347ci designed for Power Adder
No core required and there is also a discount on other shortblocks or long blocks
Main Line
