Holiday Engine special for december
budget build forged bottomend
This short block is our lowest cost forged short block. It features Diamond Racing forged pistons, Diamond Racing Plasma Moly file fit rings, Federal Mogul bearings,ARP rod bolts and a cam from our cam line or any off the shelf cam of your choice suited for your application. All short blocks are honed to 3.905" with proper finish for the plasma moly rings. All clearances are checked and rings are file fit according to application. Standard LS1 rods and crankshaft that have been thoroughly inspected are utilized. The assembly is "neutral" balanced before assembly.
$2950.00 with your useable core or $1000 core charge "exchange available"
The budget plus short block carries over most parts from the budget with these upgrades. scat H Beam forged rods in a 6.125" length replace the LS1 rod "rated at 900hp by scat". Bearings are upgraded to the "H" race bearing. Also included is the double roller timing chain set and cam is degree in properly. This shortblock assembly is recommended for high HP naturally aspirated or Forced induction applications
$3525.00 with your useable core or $1000 core charge "exchange available"
Budget 402
New GM 6.0L LS2 Aluminum Block, Eagle Forged Crankshaft - 4.00", scat H beam 6.125" Connecting Rods, diamond Pistons , diamond Ring Set Plasma Moly, Federal Mogul Race Bearings, Rotating Assembly Fully Balanced, No Engine Core Required ,Rotating Assembly Only Does not include LS2 Specific Parts
$3975.00
All engines are guaranteed to ship with in 30 days of receipt of your buildable core otherewise you will recive a certificate of $350 off your next purchase same thing with non core motor 30 days from receipt of payment you will be given a ship date on your day of your order .
Core returns on exchange must be returned with in 15 days or receipt of engine otherwise core will be refused. Please include a copy of your receipt with the core and a daytime phone # .
pm for more details
George
Budget 402
$3975.00
pm for more details
George
