NEW Patriot CNC Ported 243 castings $845.00 per pair !!
Are the heads listed for $1395 supposed to be stage III. If so, what is the port volume compared to the stage II for $1295? Is there any work done to the combustion chambers and if there is what are the combustion chamber sizes after the work?
Also, how long is the special going to last? I'll need my tax return in February to make my purchase
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Also, how long is the special going to last? I'll need my tax return in February to make my purchase![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Gunnar@Patriot
No, these heads are our stage II heads. The difference in the $1295 and $1395 is only unassembled and assembled. We do some hand work to the combustion chambers so they will remain at approx. 64cc.
TIA,
Larry
Gunnar, how long will the special run?
TIA,
Larry
TIA,
Larry
We have many sets on hand. We will continue to supply these as another one of the cylinder head choices we give customers as long as the supply lasts.
I know the 845 cnc heads claim to be bare, but does that include stock steel valves? Or are they truly bare and the 5 angle valve job is on the seats only? I like the idea of them being bare without springs, but not so much the idea of them coming without any valves at all...
i was thinkin the same thing as guits does the 845 cnc heads come with valves?
how else will it have a 5 angle valvejob?
you cant to 5 angles on the seats i dont think
#32
Im wondering if its got anything to do with Holden having to switch to the L92 engine Jan 1st due to emissions laws there, maybe they had planned to use the LS2? It seemed like a surprise last minute decision as the engine changed mid model only like 8 months before the next model VE was due out.
#33
So out of the two sponsors currently offering good deals, witch one makes more sense to go with. I don't want to seem cheap or anything but if i can get the same ported head pkg form Livernois for lets say $200 less than Patriot is offering ill go with them. Im new to the ported head thing so you pros out there chime in. thanks
#34
This is why we will be offering both the 243 and the LS6 style.
Pax, the intake runner is approx 227.
thanks
fuerzws6
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#35
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Bare head would mean no valves, no springs, just the heads. Patriot head I worked on was a nice piece, did some clean up and finishing work still.
#36
Originally Posted by LS1 Swapper
Hope your not serious...Actually my engine has an infinate angle valve job, before & after the angle that actually seats the valve ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#37
When we posted this on Friday, there were a few options that we can make available to customers that were left out. So in order to help everyone sort out what is best for them, we have listed all options and sorted the options by price.
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be bare with no valvetrain.
Pricing is $845.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with Ferrea valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves. No springs will come with this particular option.
Pricing is $1,075.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with OEM valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with OEM valves along with our orginal Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, and Machined spring Bases.
Pricing is $1,095.00 per pair assembled, no exchange.
New Factory 243 Patriot CNC ported Stage II assembled heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves, Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, Machined spring Bases, and Bronze Valve Guides. These heads are the best buy for the money. They are assembled with the highest quality parts at the best price available. When comparing apples to apples, you will find that these heads are simply the best value on the market.
Pricing is $1,395.00 per pair assembled, no exchange.
If anyone has any questions, please let us know. These heads have been selling fast so get your order in ASAP.
#38
can you use stock retainers on the ferrea valves?
i already have good springs and ti retainers
thanks
btw what flow numbers are you getting on a 3.900 bore intake and exhaust with the stage 2 program on these heads with the Ferrea 6000 series 2.02"/1.57 valves?
thanks
joe
thanks
thanks
joe
#39
thanks
thanks
joe
thanks
thanks
joe
