NEW PRC LS6 CNC Cylinder Heads $849pr!!
Old 01-18-2006, 10:32 AM
STRIPSTAR's Avatar
Do you have a bare 2.04 intake price as of yet? Thanks
Old 01-18-2006, 11:04 AM
LS2 Pontiac GTO's Avatar
What do the larger valves flow?
How much gain is there to be had using the bigger valves?
I currently have a 220/224 .597/.589 113 LSA cam/Kooks 1.75 LT with cats/K&N intake/Borla cat-back/slp p&p tb.
Old 01-18-2006, 11:26 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The upgrade to a 2.04/1.575" setup is $400.
Here's some flow info on the last set:
.300 210
.400 259
.500 297
.600 317
For someone wanting a awesome head at a great valve the big valve setup is still way cheaper than other options that probably dont flow near as well!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-18-2006, 12:03 PM
STRIPSTAR's Avatar
.300 210
.400 259
.500 297
.600 317
Ok, Thanks so $1249.00 for bare 2.04/1.575 cnc ls2 heads? Valve seats installed?
Old 01-18-2006, 12:30 PM
NLang's Avatar
Originally Posted by NoseUp
Would you happen to have port volumes on-hand?
Old 01-18-2006, 02:59 PM
98_LS1's Avatar
For that price they are fully assembled with the standard LS6/LS2 springs.
Old 01-18-2006, 03:59 PM
BacknBlack's Avatar
Sent PM.
Old 01-18-2006, 07:30 PM
Sent PM...
Old 01-19-2006, 12:01 AM
01ws6m6conv's Avatar
I just ordered a set.Cant wait! The ls6 heads are going on the trans am. That`ll bump the compression up to 10.5,which will work well with the 224/563 cam and longtube headers already installed.And I`ll swap the ls6 springs onto the gto(which has a stock cam for now with procharger) and swap the 918 springs and titanium retainers onto the new heads. I`ll get the best of both worlds. BOTH cars will run better!!!! I just couldnt see spending 440 for a valvetrain upgrade on the gto when for 849 I get ls6 heads. SWEET!!!!!
Old 01-19-2006, 08:37 AM
80superbu's Avatar
Damn...need more cc's
Old 01-19-2006, 12:34 PM
Dan
Dan's Avatar
What are the HP gains over stock LS1 Heads? I just want to bolt these up & go..
Old 01-21-2006, 06:17 PM
  #32
STRIPSTAR's Avatar
.300 210
.400 259
.500 297
.600 317
What kind of valves are used? and can you get sans springs? How much to mill?
Old 01-24-2006, 02:47 AM
  #33
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
We can do something similiar with 6.0L heads, which are around 71-72cc chambers and mill them a little if you need slightly less than that.
Should have some results posted pretty soon of the Stage 1 PRC LS6's.
Stripstar, we normally use Manley and/or Ferrea. Some ports work better with one brand over the other, depending on the head itself. Also, the 2.04 and 1.575 valve job can be cut into the stock seats with good results, going bigger than on the intake that would require a seat replacement.
The LS6 springs are free, so no price difference with or without them. We already mill about .002-.003" from each head for cleanup, so if its not much more than that we can cut it for no additional as long as its nothing crazy.
Old 01-24-2006, 02:42 PM
  #34
The car picked up over 30rwhp & 26lb ft!! Checkout the results in the dyno section!
__________________
Jason
2005 Twin Turbo C6
Old 01-25-2006, 10:18 PM
  #35
I ended up upgrading to the 2.04 amd 1.575 valves along with the double springs with titanium retainers.Cant wait to get them on the trans am. I will be taking the comp cams 918 springs and titanium retainers off the stock heads on the t/a along with the hardened pushrods and install them onto the goat.
Old 01-29-2006, 11:18 PM
  #36
hugger1975's Avatar
.300 210
.400 259
.500 297
.600 317
ordered mine
Old 01-30-2006, 01:17 PM
  #37
hugger1975's Avatar
Jason,
are these in stock?
how long is the wait?
Old 02-04-2006, 04:41 AM
  #38
cry-baby buyer
BLO BY U - TA's Avatar
Originally Posted by hugger1975
Jason,
are these in stock?
Yeah, what he said!
Alan
Old 02-05-2006, 10:20 AM
  #39
You`ll probally be waiting a while. I ordered mine on the 18 th and still havent heard or seen anything yet. I did change my order a few days later to the upgraded valves and springs. Maybe someone will chime in sooner or later. No one seems to want to answer if they are in stock and how long the wait is.
Old 02-05-2006, 10:23 AM
  #40
Trexaurs's Avatar
Sweet deal. I'll call yous guys when i have to cash together, probable next week. I'm aslo wondering, what is the turn around on these heads? thanks mike
Quick Reply: NEW PRC LS6 CNC Cylinder Heads $849pr!!
