Moser Rear End Prices At Exotic Performance Plus
what do u charge to narrow the rear end? I was thinkin of knockin half an inch off each side. let me know. Also, do u carry a heavy duty DS that will work with the 9" in a 6spd car? Need somthin that will take 5-6k rpm clutch drops with 480rwhp. Thanks alot.
-Blaze
-Blaze
-Blaze
-Blaze
Our PST 3.5" aluminum driveshaft is rated at 1200 hp, and is the correct length. It comes with a heavy duty 1350 U Joint, so no weaker conversion U Joint is used. This driveshaft will handle the abuse! Bob
Originally Posted by slmdLS1
Bob, is the aluminum center sectioned, Moser 9" with a truetrac, price $2400 shipped?
Originally Posted by Exotic Performance Plus
Moser 12 bolt/spool with 33 spline axles $1825.00 plus freight collect shipping
Moser 9 inch/spool with 35 spline axles $1950.00 shipped.
Thanks for inquiring. Bob
Check PMs
Originally Posted by z28pat
HI,
newbie question,
what would I need aside from what you send with the Moser rear ends to bolt it in to my car?
pat
newbie question,
pat
You also need a bearing press to press off the old axle bearings to remove the brake backing plates that are reused. Most Napa and small shops have a press, it only takes several minutes to do this. You reinstall the backing plates on the new axles, and press on the new Moser supplied axle bearings. Instructions are included from Moser for doing this. The center cover on the new Moser 12 bolt does not ever come off for doing this procedure, by the way. The axles are retained at the ends, as there are no C Clips.
Hopefully this helps. Bob
You dont have to press off the bearings on the stock rear end, they are not attached to the axle. You pull the c-clip and the axle slides out, then 4 bolts hold on the brake bracket to the rear end housing. You do have to press the bearings onto the new axle however. -Jeff
Originally Posted by SVC707
please pm me a total for 9" truetrac posi unit, 31 spline axles, drain/fill plugs, no abs, 3.50 gear ratio along with correct driveshaft for 6 speed transmission
$2430.00 for the Moser 9 inch with the Truetrac, 31 spline axles, drain/fill plugs, no ABS/TCS, and 3.50 gear ratio. This includes shipping. The PST 3.5" aluminum driveshaft, rated at 1200 hp is $399.99 plus shipping. Total is $2830.00 and I'll throw in free shipping on the driveshaft, so the total is $2,830.00. Thanks! Bob
Thanks,
Bill
#34
does the 12 bolt come with the 1310 yoke or the 1350, and how much shipping to southern california, somewhere around 92704, have the money and ready to buy. would also like to know what gear sizes you have above 410s, please PM me
#35
I would estimate shipping to be in the $200.00 neighborhood. It is very hard to calculate shipping as it seems to change daily. Right now fuel prices are down.
4.30, 4.56, 4.88, 5.14 and 5.38 gear ratios are offered above 4.10.
#36
Originally Posted by Zitty'sZ
I have a UMI adjustable torque arm for my car , will it work with your 12 bolt rears? Also. could you tell me how much shipping would be to 33033? Thank you, Richard.
#40
bump for Bob, got my rear(Moser 9", 31spline, truetrac) in a timely manner last week, now to find the time to put it in, lol.
Another Bump:
I just wanted to give a special thanks to Don and everyone else over at Exotic Performance Plus. I went to them for my new 9” rear end and install. Everyone there was great to deal with from start to finish. They took the extra time to explain things when I had questions, no rushing me at all.
All I can say is the sales and service are great. If you are looking for a new rear end. Or, anything else since they stock a ton of parts.
Oh yea one other item….. If you need a tune this is the place. I saw a car come in with mid 300RWHP/RWTQ and leave with an additional 100RWHP/RWTQ, this on a Mustang Dyno.
Always nice to find a place like this, I’ll be back.
Bill
