Moser rear-end prices at Exotic Performance Plus
#42
Originally Posted by fast98
sale prices still good?
Moser 12 Bolt with Truetrac for F Body, your choice of gear ratio
Torque arm mount
33 Spline Axles with 10 year warranty
ABS (3 channel) or ABS/TCS (4 channel)
Performance aluminum cover
$2,400.00 plus Shipping
Options:
Exciter Rings installed $100.00
http://www.exoticperformanceplus.co...x.html?item=146
Moser 9 Inch with Truetrac or Locker (your choice) for F Body, your choice of gear ratio
Torque arm mount
31 Spline Axles
$2,400.00 Free Shipping by UPS
Option:
Aluminum center section $135.00
Drain Plug $35.00
http://www.exoticperformanceplus.co...x.html?item=145
Torque arm mount
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Free Shipping by UPS
Options:
Drain Plug $35.00
Moser 9 Inch with spool, your choice of gear ratio
Torque arm mount
35 spline axles
$2,250.00 Free Shipping by UPS
Options:
Drain Plug $35.00
http://www.exoticperformanceplus.co...x.html?item=148
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,000.00 Free Shipping by UPS
I recommend the 9 inch rear for the higher horsepowered cars, and for those who have a manual transmission. Here is why.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I think the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Call us at 260 244-4808. Rear ends are ready to ship two days after order is received. Thanks! Bob
#44
I have an Lt1 car and was wondering about the ABS. I saw that there are two options for 9 inch rears and was wondering if i needed to buy the rear designed for the ABS or is that only for LS1 cars?
#45
#46
TTT, still wanting to know..
#49
Originally Posted by 1fastTransAm
so does that free shipping inc. Hawaii????
#51
COMPLETE ALUMINUM CENTER SECTION
Save up to 14 lbs with a Moser Aluminum case. Our thru-bolted center is one of the strongest units on the market. Moser aluminum cases are made of 356-T6 aluminum with 7075-T6 aluminum caps and billet steel adjusters. They feature a super strong thru-bolt design to give the case increased strength and decreased ring gear deflection common in most aluminum case designs. All Moser Aluminum cases are drilled for the 3/8” stock pinion studs and 7/16” heavy-duty studs. Moser aluminum cases are designed to be used with either a standard pilot bearing with snap ring retention, or a heavy duty, wider pinion bearing utilizing button head bolts for retention is available. Step up to the best thru-bolted aluminum center section on the market!
Bob
#53
Originally Posted by vteccrxsi
Can I get a moser 9" with a tru trac and the complete aluminum center section?
Thanks for inquiring!
Nice first post, by the way! Bob
