FREE MagnaFuel fuel filter
Buy any MagnaFuel fuel pump and regulator and get a FREE MagnaFuel billet fuel filter.
ProTuner Series
Engine Hp: up to 2,000+ NA
Once-piece design is more compact and light weight.
* Ideal for street muscle cars
* Quiet operation
* Self priming
* Continious duty
* No pump shaft seals, no leaks
* Pump body CNC machined aircraft aluminum
* High-torque custom motor with very low current draw. Never requires stepdown
* More efficient than other motors
* Double support bearings
* Rebuildable to as-new condition
* Compact design fits in smaller spaces
* Smaller than competive pumps, lower current draw, more powerful
* Hard anodized, long lasting finish
* Mounting bracket included
* Vertical or horizontal mount
* Polymer wear plates for smooth, quier operatio
MP-4303 2,000+NA HP 20–120psi 14A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
MP-4301 1,500+NA HP 20–120psi 12A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
MP-4302 1,000+NA HP 20–120psi 10A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
Offer good till 2/1/07
Have a good one
Nate
ProTuner Series
* Quiet operation
* Self priming
* Continious duty
Have a good one
Nate
Don't see the 4303 pump on your website but you do have the 4302 listed twice.
Do you sell a complete kit with everything you need for a stock tank setup with these pumps? how much? i need something, maybe your fuel tank kit but I don't know if I want to spend that much right now, to many other parts to buy . need something to support 700-800whp FI.
Dan
Dan
Sorry you are right it is miss labled.
MagnaFuel 4303 2000hp inline street fuel pump $529.99
Sure do give me a call I will help you setup something.
Nate
Nate
