Darton 4.130" Finish Bore 2003 LS6 Block, ARP Main Studs $2200 Plus Ship
Hey All,
I have had this block around for a little while and am looking to make some room. The original customer changed to a C5R block in the middle of the build and this block got set to the side. As the title says, it has a 4.130" finish bore, ARP main studs w/ stock caps and has been line honed. Hopefully the pics I am attaching will work okay. The block came out of a 2003 Z06 with approx 3000 miles on it at the time. This block has not been re-assembled since the sleeve install. $2200 plus freight.
I do believe I have a set of used Diamond 11509 pistons and pins available for that will fit this block also that are in good shape and just need to be cleaned. They were in a similar engine with about 2000 Miles on them and the customer went from N/A to a Prorcharger. $300 on the pistons and pins if you buy the block.
http://i112.photobucket.com/albums/n...s/DSC00251.jpg
http://i112.photobucket.com/albums/n...s/DSC00248.jpg
http://i112.photobucket.com/albums/n...s/DSC00247.jpg
http://i112.photobucket.com/albums/n...s/DSC00242.jpg
Feel free to e-mail me thevettedr@aol.com or call 407-616-2518 during the day. Thanks.
Mike Norris
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Mike Norris
The actual install was done by Auto Machine here in orlando who had done several Honda Darton installs. The finish work was done by CRE of Orlando and this is the shop that handled all of my LSx machine services. Everything was done per Dartons latest instructions as well as advice from Steve and Howard. Hope this helps.
Mike Norris
Mike Norris
