Wilwood Special Pricing Starting at $1495 Through 5/31/07
Hey All,
For those wanting a great brake upgrade and price, I am offering a package most should be able to handle.
The base package includes the Wilwood 140-7763 13" front 6 piston kit with slotted rotors and black calipers, front lines, safety wire pliers & stainless wire for rotor assembly and 3 containers of DOT 4 fluid for $1495 plus shipping.
You can upgrade to drilled and slotted rotors for and extra $95 and to red calipers for an extra $100.
This pricing structure is also good for any other kit that Wilwood offers, so feel free to PM or e-mail me with your application for a price quote. You can check out www.wilwood.com to get an idea what else if offered.
Thanks.
Mike Norris
Thanks.
Mike Norris
Technically there is not a rear kit for the rear of a 98-02 F-body per Wilwood tech line. They have a couple 93-97 rear kits and one on their site says 93-2002. Summit shows it fitting a 93-2005, fo figure.
With that said, I would GUESS that a 93-97 rear kit MIGHT fit a 98-2002 with no traction control. I have no idea that if it did in fact bolt on whether or not the parking brake cable would fit or work.
Wilwood tech did say they are working on a 98-02 specific kit, but still at least 4 weeks away which usually means there is no release date scheduled and do not hold your breath.
With that said, a rear kit 93-97 F-body 140-7148 with vented one piece GT rotors and black calipers would run $549. A complete kit front and rear would then be $2044 plus shipping. A set of front and rear lines would add $130 ($65 each axle).
Again, I am not saying this rear kit will fit a 98-02 F-body and if it is purchased and does not fit there is no return available.
Hope this helps and thanks.
Mike Norris
Mike Norris
Here are the install instruction links and they have a measurement picture to see what wheel clearance is needed.
13" http://www.wilwood.com/PDF/ds446.pdf
It looks like the body of the caliper is out approx 1.73" from the mounting surface for the wheel. Hope this helps and let me know.
Mike Norris
Mike Norris
Originally Posted by BruZer28
I have TT2's and tried them over Wilwoods. I would need a 3/4 spacer to keep them from hitting the spokes. I would be all over this to if I could get them to fit.
E
