Great Deal on Forged Pistons/Rods For Iron or LS2 Block!
We ordered a set of custom Diamond Racing forged dished pistons for a customer that has now decided to build a 402 cid LS2 stroker. Below is what we're selling:
*Diamond Racing 4.010" Bore, 3.622" Stroke, 6.100" Rod Length, -13.7cc Dish Piston Set, Custom-Built to Accept LS1/LS2 or L92 Cylinder Heads - New In Box with Wrist Pins
*Manley 6.100" Forged Connecting Rods with ARP Bolts - Used 10,000 miles
We are selling the pistons, pins, and connecting rods for $650! This is a great deal for some looking to build a strong, forged setup. You can pair it up with a factory GM crank. Depending on the cylinder head and head gasket used, you can set it up with a compression ratio as low as 8.75:1 with a thick gasket and 72cc head or as high as 10.0:1 with a .040" gasket and 62cc head. It could be even higher if you decided to mill the heads. The $650 price does not include a ring set, but you could add a plasma moly ring set for another $150.
Give us a call with any questions or concerns. We have them in stock, ready for a new home!
Jason
Texas Speed & Performance
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
