NEW PRODUCTS, Black Series Display Controllers.
Guys I wanted to share these new innovative products with you. This gauge series is manafactured by Trick Performance. WE will be carring there full line of electronic gauges.
The Black Series Display Controllers! The V and P are just 2 units so far. These units are not just gauges, but controllers as well. Clean and bright graphics added to state of the art controlling features make these units easy to read, and VERY powerful, and they both still fit into any 2 1/16 gauge area. You will be able to see what is going on with your nitrous system like never before. Each gauge has programmable inputs for 2nd pressure sensors or wideband air fuel reading. When an area exceeds a safety set point the units will disable your nitrous system. So in the case of air/fuel you can watch air fuel while driving around and but when you ready to spray if you go lean it shuts the nitrous system down.
So if you are looking for something different then just a needle moving around or bulky box type controller, then these are the gauge/displays for you.
And to make this a special for PTN the first 25 customer will receive FREE freight. Shipping to start is 3 to 4 weeks.
V = 375.00 Retail
V is the only gauge in the world that can answer that age old question that has been asked for decades, How much nitrous do I have left in the tank? Its computer processor core can calculate how much nitrous you are using and how much is left when done. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any nitrous system from single stage simple systems up to dual stage progressive systems; even the purge usage is calculated. You simply program the unit to your nitrous system. V is not just a gauge its a controller as well. V can; control the heater, shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. A warning flash will let you know you have a problem and where that problem is. V will tell you, your nitrous pressure, fuel pressure or O2 reading, if the heater is on or off, nitrous level in % form, and nitrous level in color bar graph form. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 3 main viewing screens to choose from with just a push of the control button. Fits any 2 1/16 gauge pod. You also get to choose your bottles color with in the display.
Vcan take the place of :
1 Nitrous Pressure Gauge
1 Nitrous Pressure Shut Down Switch
1 Nitrous Heater Toggle Switch
1 Fuel Pressure Gauge
1 Fuel Pressure Safety Switch or FPSS
1 Air/Fuel Gauge (Instead of Fuel Pressure Gauge/ FPSS)
1 Air/Fuel Shut Down Switch (turns nitrous system off if running lean or rich requires a wideband with programmable output)
1 Heater Control Pressure Switch
1 Digital Bottle Weighing Scale
*Pressure sensors are required for any pressure reading, and for heater control feature to work.
P = 399.00 Retail
P is the only gauge in the world that is a progressive controller with mutli-point ramping capabilities. Its computer processor controls the nitrous system completely including the heater. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any single stage nitrous system. You simply program the unit to your nitrous system. P is not just a gauge its a controller as well. P can control the heater and shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. Its a progressive controller, window switch, TPAS switch, nitrous pressure gauge, shift light. A warning flash will let you know you have a problem and where that problem is. P will display, your(nitrous, boost, fuel, or oil pressure), O2 reading, is the heater on or off, nitrous progressive level, rpm, inside or outside the window switch setting, WOT activation. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 8 main viewing screens to choose from, with just a push of the control button. Fits any 2 1/16 gauge pod.
Progressive controller (time or rpm based)
RPM window switch
Wide-Open-Throttle detection when used with factory TPS or WOT switch.
Supports Fly-by-Wire TPS rising or falling
5 Point variable Progressive ramping (time or rpm based)
Shift Light
Rich l Lean Cutoff (when used with a wideband)
Air/Fuel inputs Digital or Analog
Multiple wideband capabilities
Heater controller
First gear lockout / delay
8 different Main Viewing screens.
Programmable Power UP screen and Arm screen
Multiple pressure choices
Pressure display (boost, nitrous, oil or fuel)
Micro-Solenoid Driver :
This unit is included with ever P gauge. Additional unit(s) are required, if more then 1 nitrous and 1 fuel solenoids are being use.
Small compact size fits anywhere
1 x 1.5 x .75
Water tight construction
40 amp capable
Mounting tab
Long wire leads
Easy parallel wiring
These units are not up on the website yet. It will take a few days. You can place your orders now by calling 1-866-648-7637.
Thanks
Dave
Ok guys. I am getting tons of calls and pms from people that are excited about the gauge's but confused by what all it can do since it has so many options. I am hoping this post will clear some of the confusion up. Feel Free to ask any questions.
THE V GAUGE.
Out of the box this gauge will offer the following fuctions.
1.NITROUS VOLUME USAGE.
2.AIR/FUEL READING. (Plugs into your wide band)
3.NITROUS SYSTEM SHUT OFF. (Shuts nitrous system of in relation to air/fuel readings)
4.Bottle Pressure gauge(Requires you buying sensor # SHP-1500- $60.75)
5.Nitrous Shut off ( You have to be using option #4 with the sensor for this to work. If bottle pressure is to high system relay will not triger)
OK,
Now that we see what it does out of the box lets talk about add on features. You are allowed to monitor one pressure using all the features that the gauge offers out of the box. This pressure has to be bottle pressure. If you do not have a wideband and do not need the gauge to be used as a wideband gauge you can use the gauge to monitor two pressures instead of one. So now you can add a second pressure to monitor. All the add on features require you buying the needed pressure switch.
Here are your pressure other options.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.A SECOND NITROUS PRESSURE
5.WATER/COOLANT TEMP
6.OTHER (any other pressure option you may need)
NOW THE P GAUGE.
Out of the box the P GAUGE offers alot of options.
1.PROGRESSIVE CONTROLLER ( Multipoint ramping with RPM and Time base options)
2. SHIFT LIGHT
3.WINDOW SWITCH
4.TPS ACTIVATION SWITCH
5.FIRST GEAR LOCK OUT/DELAY OPTION (Aids in traction limitied applications)
6.AIR/FUEL READING (Plugs into your wideband)
Ok now that we have went over what the gauge does out of the box lets go over add on features. The P gauge is designed so that if you have a digital out put wideband such as the new FJO series you can use the built in digital input that the gauge has. This now free's up a area giving you the option of adding a pressure to monitor. (You will need to buy the needed pressure switch)
Pressures you can monitor are.
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.NITROUS PRESSURE
Guys let me know if you have any questions at all.
Dave
THE V GAUGE.
OK,
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
NOW THE P GAUGE.
2. SHIFT LIGHT
3.WINDOW SWITCH
1.FUEL PRESSURE
2.OIL PRESSURE
3.MAP PRESSURE
4.NITROUS PRESSURE
Dave
