It's BACK! FREE SHIPPING + discounted cam swap gear! Springs, gaskets, cams!
Hey guys,
Back by popular demand, we are offering free shipping *AND* discounts on all the gear you need for a cam swap, including:
* Patriot Performance Valve Spring Kits
* GM Gasket Kits (timing cover gasket, water pump gaskets, front seal, and balancer bolt)
* Comp Cams Camshafts (pick your grind, or we can help you pick one)
We will be offering these as three separate packages.
![](http://www.mphparts.com/mm5/graphics/00000001/patriotsprings.jpg)
Package A consists of the Patriot Performance Valve Spring Kit only. Your choice of Patriot Dual Gold springs or Patriot Dual Extreme springs. The spring kits include springs, titanium retainers, machined bases, viton rubber intake and exhaust seals, and Super 7 locks.
To get the discount on this item, CLICK ADD TO CART after going to the product page (you cannot see the discount without clicking ADD TO CART):
Patriot Golds: http://www.mphparts.com/mm5/merchant...pon_id45=PP-10
Patriot Extremes: http://www.mphparts.com/mm5/merchant...pon_id45=PP-10
Package B consists of the Patriot Performance Valve Spring Kit PLUS a cam swap gasket kit. Your choice of Patriot Dual Gold springs or Patriot Dual Extreme springs. The cam swap gasket kit includes the front timing cover gasket, harmonic balancer bolt, front main seal, and water pump gaskets.
Package B is $289.99 for Patriot Dual Gold Springs with the gasket kit, or $313.99 for Patriot Dual Extreme Springs with the gasket kit, SHIPPED.
Again, to get this discount, go to the spring page of your choice and enter the code PP-10 into the promo code field, and then click add to cart.
![](http://www.mphparts.com/mm5/graphics/00000001/compcamshaft.jpg)
Finally, package C. This is the valve spring kit, gasket kit, and a Comp Cams custom camshaft of your choice (or we can help you pick one).
For Patriot Dual Gold springs, this package is $649. If you'd like the Extreme springs instead, it's $673.
![](http://www.mphparts.com/mm5/graphics/00000001/mphcampkg.jpg)
We have added this package with savings built-in, so there is no need to enter special coupon or discount codes. Again, these packages ship to you absolutely free!
To order package C with dual Golds, click here:
http://www.mphparts.com/mm5/merchant...Category_Code=
To order package C with dual Extremes, click here:
As always, feel free to give us a call or PM or email us if you have any questions. We also have live chat available on our website if you prefer!
Tony
Tony
