Mototron/Siemens, Fuel pumps, hot wire kits, LS1 timing tuner
60 LB Siemens/Mototron (sold as 63 and 65 also) Long injectors in matched sets of 8 $380 ($47.50 each)
99-up LS1 f body direct fit fuel pump kits that retain bucket function $119.99
99-up LS1 f body fuel pump hot wire kits $49.99
LS1 Timing Tuner and N2o controller. Control timing, Take a pump gas tune to race gas, control N2O system, add N2O retard. Window switch, delay start for N2O. Hundreds sold! $219.99 (works on LS2 with 24 tooth reluctor I.E. GTO)
These are limited time specials so act fast
thanks
Mike Licht
thanks
Mike Licht
what is the difference on the length of the injectors. I am looking to build a turbo 402 and I will probably be running speed inc fuel rails and a stock ls6 intake and then a fast intake later as money comes along. would these work or not? Let me know. How long is the sale for and is there a limit to how many you are going to sell. Thanks Chris
