Moser rear end prices at EPP - Rears shipped two days after ordered!!!
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Powercoating by Moser, is now available!!! $250.00 at time of order!
Moser 12 Bolt with Truetrac for F Body, your choice of gear ratio
Torque arm mount
33 Spline Axles with 10 year warranty
ABS (3 channel) or ABS/TCS (4 channel)
Performance aluminum cover
$2,600.00 Free Shipping by UPS
Options:
Exciter Rings installed $100.00
http://www.exoticperformanceplus.co...x.html?item=146
Moser 9 Inch with Truetrac or Locker (your choice) for F Body, your choice of gear ratio
Torque arm mount
31 Spline Axles
$2,400.00 Free Shipping by UPS
Option:
Aluminum center section $155.00
Drain Plug $35.00
http://www.exoticperformanceplus.co...x.html?item=145
Torque arm mount
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Free Shipping by UPS
Options:
Drain Plug $35.00
Moser 9 Inch with spool, your choice of gear ratio
Torque arm mount
35 spline axles
$2,250.00 Free Shipping by UPS
Options:
Drain Plug $35.00
http://www.exoticperformanceplus.co...x.html?item=148
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,000.00 Free Shipping by UPS
I recommend the 9 inch rear for the higher horsepowered cars, and for those who have a manual transmission. Here is why.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I think the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Call us at 260 244-4808. Rear ends are ready to ship two days after order is received. Thanks! Bob
Torque arm mount
Options:
Torque arm mount
31 Spline Axles
Option:
Drain Plug $35.00
Torque arm mount
31 Spline Axles
Options:
Drain Plug $35.00
Torque arm mount
35 spline axles
Options:
Drain Plug $35.00
