NEW Precision Race Components CNC LS3 Info Pricing, Components & Hollow Stem Valves!!
Guys we're proud to announce that we've finished up development & testing of the final version of our PRC L92 / LS3 cylinder head! We've now broke down the LS3/L92 heads to be available in several different versions. Customers will now be able to select from the following options:
Stock L92 Valves CNC PRC Ports
(better than stock p/v & available chambers form 64cc-72cc)
$1079
Upgrade To Stainless Manley Valves
$50
Upgrade To PRC New Hollow Intake Valve & 1.60" Stainless Exhaust Valve
$140
Install PRC Platinum Spring Kit
$250
The all new PRC Hollow Stem valve option saves huge amounts of valve weight without the crazy costs associated with titanium valves.
Stock Valve Weight 106 G
Stainless Valve Weight 122 G
Hollow Stem Valve Weight 91 G
https://texas-speed.com/shop/item.as...d=697&catid=40
The new pricing gives our customers the ability to buy the best possible L92/LS3 cylinder head for pricing that compares with the newly released GM cnc ported cylinder heads.
Dyno testing from the PRC L92/LS3 cylinder heads have show over 20hp gains over the stock l92/ls3 cylinder heads!
$1079
$50
$140
$250
![](http://precisionracecomponents.com/418heads.jpg)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
